Started to mess about with a video cam so my first Porsche video !
Amature at best but it gives you an idea ...
Ok so the trims have been removed here so that you can see the operation .. normally most of this is hidden ..
Car came in with a jammed blind and roof not working .. for safety reasons the roof won't operate unless the blind is full closed .. it was jammed , couldn,t close so roof didn't work .
I reassembled the blind to get it working to see what was broken .. both plastic guides needed replacing as insecure ..
I did this then went about finding the actual cause of the blind failure ..
The center seal had come detached and was catching the bow spring and knocking it off .. these seals are often very low on these and can catch .
I replaced the seal .. hell of a nasty job and ended up with 3 mm of clearance .. thats huge !! .. no more catching on the bow spring now .
https://youtu.be/ZyDWy9yWEpo
