Jungle650 said:dward85 said:Jungle650 said:For the money its worth thinking about upgrading the PCM rather than paying for newer maps - which will already be out of date.
On my 991 I went down the NM Automotive route and never looked back. See below link.
http://911uk.com/viewtopic.php?t=146206
Jungle
This is an awesome post, how would the NM unit work if you have front/rear parking sensors but also want to add the camera module (either rear or front&rear)? Couldnt figure this part out.
Thank you.
Parking sensors front/rear work in unison with a camera/cameras. Obviously adding the camera for example to the rear of the car provides the picture and the parking sensor information is overlayed ontop of the picture by the NM Automotive box. The sound beeping acts as it did before. The great thing is that even if you dont use Apple car play and have the PCM in its original mode - (pressing and holding info button on the PCM switches between stock PCM function and Apple Car Play ) adding a camera still works- as if it was there from the factory, along with peeps. So in short everything just works.
As seen in pic below:
Wow i didnt expect it to be so seamless! Thanks so much for detailing that out along with the picture. There's literally no reason not to do this. One more question though, if a front camera is added. Do you have to toggle between the two, or do they both show up? And what if i just want to turn on the front camera....i have a tricky garage situation going on for when i pull in.
Though im still a bit hesitant with wiring in cameras ever since the C63 AMG burned down the entire garage because the people wired the camera is wrong and it set the car on fire
