964 jacking points
Dave Barker
19 Oct 2006
11
Hi
Being quite new to Porsche I wonder if anyone could advise me on the best (and safest) place to use a trolly jack, front and rear on a 1991 C2 964 please. Thanks Dave
Migration info. Legacy thread was 89251
on all 4 end of the main body, but in the manual if you have it ? it does IIRC list the positions but should be (on the 993) a plate / section for the jack..... so all in all a very normal position for a trolly jack
if only sid was here to give the answer by a techie !
Migration info. Legacy thread was 89256
Dave, the safest thing is to use a jacking plate:
/images/migration/UploadedForumImages/Budget%20Jacking%20Plate.jpg
Budget version �20 + VAT
/images/migration/UploadedForumImages/Jacking%20Plate.jpg
Pukka version �60 + VAT
Then use the jacking points for the standard jack
Migration info. Legacy thread was 89259
Unless you use one of the above fittings the metalwork which accepts the useless jack supplied with the car can easily be squashed flat with a trolley jack. Ask me how I know...
Don't be tempted to use any suspension point or engine/ gearbox point without taking professional advice from someone who really has the knowledge.
Migration info. Legacy thread was 89297
Two jacking points each side. One just behind front wheel arch and the other just infront of rear wheel arch both near outside edge of car (exactly same position as 993 Sundeep). Easy to see as its a solid looking flat bit of metal with a hole in it for the jack. Can be quite difficult to get a jack under unless it is a low clearance item. You will need some sort of puck as posted above (although I have done it without but it can damage the plate).
Ian.
Migration info. Legacy thread was 89392
124,626
1,442,194
49,057
VeeRacer
