DynoMike said:There could have been one more explanation. If, as Tom has said, you had a vacuum leak on idle, this would not have been picked up due to the maf delete. In certain circumstances the idle mixture could be slightly richer than ideal, the extra air being induced then causes the idle to raise which the ecu sees, then retards the ignition to try to maintain idle target value.
With retarded ignition the burn happens late, this causes some minor spool on idle. In other words, this is the basis of anti lag systems the world over, it's just that in this case the air may being supplied by a temporary vacuum leak rather than a jacked throttle or a bypass valve. The same thing can be attained by playing with the overlap via the variocam, but this would happen at all times.
I'm not saying this has happened, but it is possible, especially if after driving the car harder today has helped seal any potential leak due to a heat increase. ~But that is a long shot!
Oooof!
Pick that one out! :worship:
Will keep an eye on it then Mike and see what happens. It wouldn't surprise me, looking at the logs done in the past, if ES haven't fiddled with the timings along with the mixture to make all the pops and bangs in the exhaust...
Since I got the tune done I've had a CEL (P0171, P0174 (idle range banks 1&2 above limit)) which I believe is due to it running slightly lean at idle and partial throttles. This is probably due to the big injectors which it has and Emre trying to get them to only inject a tiny bit of fuel.
I haven't really bothered about the CEL because I wasn't doing many miles in it, but now its got a new engine and i'm doing more miles in it I want it sorting.. I've contacted ES who are happy to adjust the tune for me.
