Porsche 911UK Forum
Wiper switch removal?
clarkycat
Well-known member
11 May 2011
3,900
Intermittent is, well, intermittent! And they don't always auto park.
Have sussed so far, from circuit drawings and information, that the auto park switch has to make for the intermittent function to work, these two functions are controlled by the contacts thru the 'off' position.
I want to check the contacts and see if I can clean them up, can't find any internet guide on removing the wiper switch, is it self explanitary?
You will need to remove the airbag, steering wheel & clock spring, then the whole switch assembly comes off as one held on with couple of screws I think.
You might want to try some switch cleaner on the switch before you take the wheel etc off
Also check the relay and the connector to the switch, may save you having to remove the switch
If you do need to take the switch apart, unlike other switches on the car it is not so easy to get apart, as its riveted together, but it can be repaired with patience
Although because of all the hassle, it may be easier to just fit new or a good second hand one
123,990
1,436,086
48,361
YJY
