Wiper Blade - How odd!
911UK
Administrator
Staff member
15 May 2002
14,969
Well if anything is going to break on your 993, you don't expect it to be this...!
/images/migration/UploadedForumImages/P1010056.jpg
That's the last time I ever decide to wash it, maybe a wheel will fall off next time.
Migration info. Legacy thread was 15566
You interior looks a bit clean!
Migration info. Legacy thread was 15572
Nothing surprises me with these cars any more !
But who needs a rear wiper anyway - it spoils the lines.
Have you had the "self-disconnecting" door release linkage yet? (The little plastic connectors wear out & then the metal rod pops out. Its a door panel-off job to fix).
Migration info. Legacy thread was 15581
Thankfully, no, not yet, but give it time!
It looks to me that the whole wiper assembly will need replacing...££££ I suspect
Migration info. Legacy thread was 15582
Hi Phil -
I had exactly the same problem on my rear wiper, the same break in the arm at the same place - obviously a design fault. I didn't even get a quote for the part though, because I saw this article -
http://p-car.com/diy/rearwiper/
I removed the rear wiper as described and saved the bucks, also the 5lb weight and I also think it looks much better!
The only time I miss it is if you park in the rain, but the rear demister does a reasonable job of clearing the vision. While moving rain does not settle.
LJ
Migration info. Legacy thread was 15585
Many thanks for the link LJ - That looks so much better - I shall do the same.
Where did you source all the bits from?
Migration info. Legacy thread was 15586
Phil, All I bought was a grommet pack of 3 from Halfords. I think they were 24mm but can't be sure. You need one in the rear parcel shelf and another in the rear window. Total cost around £1 for the cheapest performance/looks upgrade ever. :wink:
The DIY guy put a grommett in the rear window and then put a washer on either side and a nut and bolt through it - undoubtably more secure but I thought it would look scrappy and so just went with the plain old grommet and it works perfectly.
LJ
Migration info. Legacy thread was 15598
It gets even better! Nice little job for the weekend :D
Migration info. Legacy thread was 15600
Trending content
126,730
1,472,645
52,293
khixson
