Window Problems?
coomo
24 Oct 2013
361
So was feeling pretty smug with myself, as despite club like mitts, I managed to fit a new micro switch(one that connects to door handle) to cure my cars window fault.Not dropping down when closing.
Not only did the fix not work, its now worse! and thr window wont close unless you "hop" it up with blips of the switch (which I also replaced)and just to rub salt, into my already sore wound,The ***** airbag lights come on!
:sad:
Have I replaced the wrong switch, or am I stupid?
My window is driving me nuts too!!
Just changed all the door lock and its the same - sounds like I have a door lock that might fix your problem and you have the micro that might fix mine!!
Did you disconnect the air bag??
what side has the problems on yours??
Hopefully someone will come along with a bit more knowledge than us plums!
:sad:
Have you "re-taught" the lift mechanism its end-stop position?
IIRC, you have to raise the window to the top position by keeping your finger on the button, release the button, and then press it just once more to store that setting in the control unit. :dont know:
Mines the poxy driver side.About 90 minutes work,Its a c**t of a job too! you need really small hands to get the nuts back on the handle.Luckily my mate has hands like an action man and helped me out.
Mine cant be the lock, as its the window thats playing up!! :?:
:sad:
i cant I have to jog the window up now!! Poxy electrics.Suppose Ill waste more of my life tommorow trying to sort it.Then off to the local indy!
The lock has 3 micro switches in it that are also part of the window control - I think there are 7 in total...
Yeah not a nice job - especially when it hasn't worked!!!
I found a video of how to clean the micro switch.Apparently its the same as a VW .One.IF your courtesy light does not work.Its the micro switch on the lock mech.Mine doesnt so thats the next one to try.
Trending content
126,794
1,473,629
52,374
Flat6ixDevelopment
