Will these wheels fit?
davirus82
11 Feb 2015
50
Hello 997 team,
I have a 54 plate 997 Carrera S with lobster Claws which I believe are: Wheel Size 8J x 19 ET57 & 11J x 19 ET67
I am looking to replace potentially with:
Rears: 11J X 19 H2ET 67 Part No: 997.362.163.00
Fronts: 9J X 19 H2ET 57 Part No: 997.362.157.00
Will the fronts fit? Apologies if this is a silly question.
Cyrus
I'm fairly sure that exact wheel is listed as an option for my 2004 C2 (non S) model. I'll check my manual later today and post a pic.
Mac68
That front wheel comes up as an 8J, which makes sense.
Thanks very much, was confused when it showed 9x19 on the ad.
Thanks for clearing up
The fronts are the same offset as the standard wheels but an inch wider.
So you will have 1/2" less outer and inner clearance, I'd say outer may not be an issue as it's the same as fitting a 12mm spacer to a standard wheel which I believe plenty have done.
I'm not sure about inner clearance with the suspension but you can easily measure and check yourself. :thumb:
124,574
1,446,444
49,719
Damos_Cars
