Whistling noise coming from engine
Chris H
21 Aug 2003
9
Having recently purchased a 1993 964, I was extremely happy with life until a few weeks later when I approached a corner doing a few click's faster than the weather would allow, and consequently became another Carrera 2 statistic... Ouch ! Left side damage, front and rear..
All has now been fixed and she is looking better than ever... Only problem I have now is a whistling noise coming from the engine when accelerating. It seems to come in at lower rev's and then dissapears as rev's go higher... Could it be a problem with one of the belts?
Any ideas?
Migration info. Legacy thread was 11618
Can you fatten out your description a little. Whistling like in one of those old C&W records....... a kettle a train?
Migration info. Legacy thread was 11622
Chris, did you ever get an answer/fix RE your 964?
I have the same thing (worse when cold), and when you accelerate it goes, only to come back into earshot when you stop/idle etc. Sounds to me like a rhythmic squeal/pitch - could be the belts????
Anyone???
Dan
Migration info. Legacy thread was 38304
my drilled airbox whistles if that helps
Migration info. Legacy thread was 38307
I'm lost? its definitely a high pitched on/off squeal
Migration info. Legacy thread was 38310
Slipping belt? But then that might get worse the higher the engine speed. Check belt tightness everywhere.
Pulley bearing somewhere?
Migration info. Legacy thread was 38311
I had some whistle noise from the engine when on idle a while ago, mainly when engine's cold.
I thnik there's a section in p-car.com about belt tensioner bearing or something. The noise stopped after a while so I never got to find out.
Migration info. Legacy thread was 38314
Trending content
126,723
1,472,539
52,289
Robbos
