Porsche 911UK Forum
Where is the switch
Ghost
Well-known member
11 Sep 2006
3,977
in the 993 bonnet compartment that controls the under bonnet light?
<awaits cries of "check the manual" >
Migration info. Legacy thread was 111314
Didn't know there was a manual switch tbh, you could frigg the one at the front latch to think that the bonnet was down?
Migration info. Legacy thread was 111320
There isnt a switch. if you want to turn the light of then close the bonnet latch / lock with a screwdriver and the light will turn off (make the light think the bonnet is down)- just remember to pull the lever in the cabin before you slam the bonnet shut.
Oh and "CHECK THE MANUAL" !!!!
Migration info. Legacy thread was 111327
Previous poster said:
:D
Migration info. Legacy thread was 111329
Take the bulb out and replace it with an led bulb which draws a fraction of the power - then you can leave the bonnet open while you charge the car.
Migration info. Legacy thread was 111386
...which must save additional £££ a year!
Bear in mind you will also need to turn off the interior light, which also comes on with the bonnet up for some reason.
Migration info. Legacy thread was 111388
did not realise there was light - whereabouts? i keep the bonnet (boot?) open an inch to let the CTEK cable in to the battery - did not know this meant lights stayed on. (Did not look, or think even!)
Migration info. Legacy thread was 111391
when you stand at the front of the car the light should be at the left rear, attached to the bottom of the boot lid.
Migration info. Legacy thread was 111400
thanks Fuchs - just found it. Unless it were on, one would hardly notice it was there!
Mine is not on, so i guess i need to change the bulb. Perhaps i burnt it out by having the bonnet open most of the time the car is parked!
Does the lens pull out easily to allow this? I can get a finger nail under one end and can lift it, but met soem resistance so decided to stop for now.
Migration info. Legacy thread was 111574
Robertb - thanks for pointing that out - thanfully my interior lights have been in the full off position. Strange way to wire things, as to open the bonnet you have to open the door - which would turn the interior lights on, then to have them stay on even with the doors closed, but the bonnet up is wierd - unless its a safety thing to tell you the bonnet has not been properly latched? Must find that manual and read it some time...
Migration info. Legacy thread was 111576
124,008
1,436,290
48,385
DocGastro
