Changing the rear brake pads on my Carrera 4S (Turbo Brakes) is giving me problems. I have 2 packs of anti-squeal shims (4 in each) that stick to the back of each pad. These in turn locate into holes in the centre of the pistons with a circular spring clip. The problem is that one pack push-fit easily into upper or lower piston, but other pack appears to have a larger diameter caliper-piston clip. Both pistons have identical size holes, and previous owner/mechanic didn’t even bother to refit them (so have nothing to compare with…).
Have I got the right parts? Do you have to use brute-force to fit larger clips? Which are top and bottom?
Don’t want to refit wrongly or leave them off again as brakes were squealing really badly without them.
Help!!
Migration info. Legacy thread was 31160
Help!!
