Underbody trays/ shield fixings
peterzoom
25 Jul 2016
281
I've been noticing that some of the threaded posts to which the undertrays locate and are then affixed by plastic nuts are rusting away.
Mostly they're fine but a few seem to be almost bereft of threads.
Has anyone come upon a solution that doesn't involve drilling them out and replacing them with the available Porsche repair kit?
Seems like going overboard to have to tear down the carpets etc.
There's got to be a better solution... Anyone??
berni29 said:
I purchased these, clean the area and metal glue them on.
https://www.ebay.co.uk/itm/403442738877
Genius! I just knew this was the perfect forum to find a practical, tried and tested solution. Thank you very much, great idea :thumb: :thumb: :thumb:
What glue did you use?
I've made up something similar to the Bighead fasteners by TIG welding a stainless self tapping screw to a large stainless penny washer and drilling a load of holes in the washer. I think the threads on a self-tapper more closely match the originals, so the plastic nuts fit a bit better.
That sounds good. JB Metal Weld
I used riv nuts to fit 997 undertrays along with the gearbox triangle, gearbox cover and rear brake ducts.
Here's my first attempts - please don't laugh at my TIG ability too noisily!
The washer is M8 x 35mm on both, the left hand version has a 5.5 x 25mm thread and the one on the right has a 4.8 x 19mm thread.
The 4.8mm version allows the nut to screw on very easily with your fingers and can be done up very tight without stripping, while the 5.5mm one is too tight to do with your fingers beyond getting it started, but it doesn't appear to stretch a new plastic nut. I'm leaning more towards the larger thread as it feels very secure without being excessively tight.
I'm going for M6 studs and proper stainless nuts and washers. Unlike Porsche I don't mind spending a few £ so it will come apart.
124,574
1,446,444
49,720
acupunch
