Porsche 911UK Forum
Tandem Pump
Barneybee
Well-known member
15 Sep 2012
62
Had a call from OPC Chester last week to say that they had noticed the Tandem Pump had some corrosion on it when it was in last. They wanted to take a look to check it had not gotten worse.
Took it in today and they said it needed replacing, luckily for me, under warranty. Has anyone else had this problem or has anyone checked theirs? The car is only 6 yrs old and done 49k.
My car is a 2007 C2S and had the pump replaced in May 2013 by my Indy, paid around £400 for it to be done, mine was dripping oil so really needed doing.
Mine is corroded but not leaking (35K), but I expect it will need doing in the not too distant future. It's a common problem with the metal used on the casing.
Chester must be quiet at the moment if they are stirring up business from previous advisories.
Nice of them to look after you.
The cover is a piece of pressed tin, un protected. If you peel the part number label off you have a nice piece of shiny metal !! If new spray or paint it with a high temp paint. Anyone wanting to set up making and selling repalcements would make a fortune.
Yes it was pretty dead there!!
I wonder if an end of month sale could be had - checking their stock now just in case they have something in my budget - fancy a Turbo now.
Nice Turbo but out of my budget right now.
Chester porsche told me it needed replacing at last service sept 2012,[£650] Depends how bad it is,i cleaned mine up and painted it with high temp paint still looking allright.But if its under warranty get it done. [997 2007, 20,000mls]
The part number is 997-107-022-02 cost £350, your local Indy or garage could fit in about an hour.
If I remember correctly, I was told by one of the OPC franchisees that its financial year end was 31 July?
124,106
1,437,241
48,500
Markyt911c4s
