Interference Fit
- Joined
- 7 Apr 2024
- Messages
- 240
Ok, a couple more steps closer today after the second pour.
But first, here is the first one that was cast last night, looking far less floppy.
A summary of upgrades to the second pour are:
The pour went pretty much the same way as the first one, there was only so much resin I could pour down the tunnel before it backed up and overflowed. It was at least entering the mould more consistently thanks to the absence of the funnel blocking the flow. This issue was that at the rate I am able to pour is slower than required to beat the pot life, and unless I can pour it at least 3 times faster, the same thing will continue to happen.
After 90 minutes, I lifted the lid. In the words of Jim Bowen from Bullseye - "This is what I could've won"...
About 20% more spoiler than last time. Not good.
However, attempt number two did show significant improvements in surface finish and lack of bubbles, thanks to the pre-mix de-gas and elimination of the silicone spray. The spoiler came out the mould just as easily with or without the spray, so I'll not bother with ti again. The data sheet for the silicone does state a release agenbt is not necessary but instinct got the better of me. As my Dad always says, "if in doubt, read the instructions!".
I cut the spoiled the spoilt spoiler a little more by cutting it into sections to better evaluate the various details.
This was the worst of the flashing, which is practically zero in moulding terms.
The flashing pretty much just wiped off with a cloth, leaving me with a finish I'm really pleased with.
The other side where flashing had potential to present was the hard front corner where the vertical element joins the mounting flange. I designed the mould so the two halves join at this very corner to minimise any evidence of flashing rectification and I'm chuffed with how this worked out. Also note the vastly improved mating face surface, free of any micro bubbles.
When I removed the lid it was effectively trapped due to the funnel contour I'd carved into the entry point. Knowing the spoiler was a dud, I just pulled it off the spoiler, which when still curing is easier to tear.
This is the profile of the entry tunnel.
This picture gives the game away regarding the flow rate challenge. The flow rate is ultimately governed by the cross sectional area of the spoiler, which with a flange thickness of 3mm means that even if I had a hole the same diameter as the width of the entire flange, the cross-sectional areas for the resin to flow through at the entry point is still slightly less than the cross sectional area of the tunnel. This means there is no point making the hole any bigger, it just won't flow any faster due to the viscosity of the resin. The 3mm cross sectional thickness further compounds the problem as due to the viscosity, laminar flow has a greater impact than it would in a cylindrical tube.
The bottom line is that I need a resin with a lower viscosity and preferably a longer pot life. If I can halve one and double the other, I'll be about right.
Disappointing, yes.
Progress in quality and understanding, yes.
I'll need to research resins for a while so this will be the last pour for a few days depending on what I can find and the postage times etc, but we march onward.
Mould box set at 45 degrees to encourage gravity to assist flow through.
No silicone spray on the mould halves
Correct mixing ratio of black pigment, now down at 4%
Part A was mixed with the pigment then de-gassed, at least this gives me a fighting chance once mixed, if I'm careful
Part B degassed
Both parts mixed carefully to try and minimise air entrapment
Disappointing, yes.
