Rain Sensor
nickt68
21 Mar 2008
72
Having my windscreen replaced tomorrow (2005 997 C2S) and fitter has asked if I had a rain sensor which I didn't think I did.
However, he asked if my rear view mirror was fixed to the windscreen and if it had a plastic "cigar shaped" tube going up towards the roof. It has both and he said that this was to do with the rain sensor and that all of the 997s he had seen had this apart from a couple. He also said that it may need re-coding to work?
Just wondered if anyone else has come across this and/or if I do in fact have a rain sensor fitted?!
The "cigar tube" also delivers power to the auto-dimming mirror (where fitted)
You need to check for the rain sensor "eye" on the back of "cigar tube" (this is visible through the front windsceen and looks like a ring of blueish LEDs)
Thanks Paul, I have got the black ring on the screen but don't think I've got the LEDs - is the tube a standard fit item and only gets wires/LEDs if you tick the appropriate options?
The 997 screen comes with a rain sensor bracket as standard, but not all cars have the rain sensor installed; some are dummies.
If the screen is 'set' correctly, it should be slightly recessed and the extruded trim should be chamfering up against the painted rebate, and not flush with it.
Try and get a peak at the paintwork after the old screen is removed.
124,313
1,444,069
49,445
AlfaMax1996
