Just to finish off the Oils breather bit.
I fitted everything up and with the silver bracket it just kept drawing the eye to the coil pack which is supposed to be hidden.
On looking back at the original photos I realised that the said bracket should be black.
So back to painting....
Much better. You really don't look past the orange oil can. I'm pleased with how this came out. Just looks like it should have always been there.
New revisit was to the wiring loom. This time the charging circuit and starter looms. I had left these until I knew how I was going to use the engine mamagement and wasted coil (also I was sick to the back teeth with wires).
Both looms handle a lot of current, so really were a fire waiting to happen after fifty years of heat and grime. On further investigation I was right. The wiring was so stiff internally and very corroded.
So another trip to the guys at the auto wiring supplies store...
De soldering all these little buggers and reusing with the new wiring caused some colourful language!
Much better and much safer.
Last image now shows the coil pack wiring. This basically breaks the pack into two sets of two. So I could reuse the coil positive from the Porsche loom and then the RED controls two spark plugs and the same with the BLUE. The centre GREEN is the live feed.
These two then route towards the battery where the ECU will be hidded. They will trigger the coil to fire.
I have finished the wiring to the logic relay under the passenger seat that controls the ignition and the seatbelt warning lights. However I have bypassed the main live to avoid issues in the future, but I wanted to reinstate the wiring just to see how it all worked.
By way of a change of scenery I started fitting the anti drum/ vibration material. I think this is going to take some time and effort!
So that's it from me for now. All have a very, very merry Christmas and enjoy time with family and friends.
