Problem replacing control arms
woodie
31 Jan 2009
61
So I've done my homework, bought new spanners and control arm parts and the car is well on the way to being in bits. After following the FAQ Guide to replacing these i thought it looks pretty straight forward. That is until the nut on the ball joint just rotates on the bal joint shaft.
I've seen there is a star socket in the top of the ball joint, so I'm off to find something from the tool shop that will hopefully fit and allow me to get the nut off.
Might be useful info for anyone else trying this to have a set of star drivers or at least not start the job without having time to go to the shops, so not a Sunday afternoon job.
Hopefully this will do the trick
Another tip to undoing ball joints when they are spinning is to put the jack underneath it and push the cone tight into the hub this usually does the trick. They don't usually spin unless you knock it out too early, I always take the nut off first all the way, then clean up the thread and replace the nut for a couple of threads then try to release the ball joint.
Thanks for the tip, worked a treat. Tried a Torx plus driver which was near on impossible to manage.
124,818
1,443,889
49,323
xx22
