Porsche 911UK Forum
Porsche Rated Tyres (N Rated)
Used Porsche
Banned
23 May 2003
2,132
From Tyresite.com
http://www.tyresite.com/tyrearticle.asp?page=14
Since most of us need these tyres and may need more info on the N rating - here it is.
Sports cars are often described as vehicles that "stick to the road." Sports car tyres make a major contribution to this phenomenon. These tyres are very complex products meeting numerous, largely contradictory demands. Finding the proper structure that balances these demands for any given application is the great challenge in tyre design.
Porsche designs and manufacturers some of the highest performance vehicles in the world. Because of the integral role that tyres play in vehicle performance, Porsche has integrated tyre development throughout their process of vehicle development. To be an Original Equipment tyre provider on a Porsche vehicle or be approved by Porsche for the replacement market requires the joint product development efforts of the tyre engineers working alongside the Porsche vehicle engineers.
Porsche Rated Tyres
The focus in recent radial tyre development for Porsche vehicles has primarily included optimum handling on dry surfaces and the safest possible behaviour on wet surfaces, even at high speeds. Tyres developed by various manufacturers, in concert with Porsche, offer a specific set of wet grip properties which few, if any, other automobile manufacturers demand in equal measure from the tyres they use on their vehicles.
Tyres may be specified for a particular vehicle or range of vehicles and must successfully pass the tyre company's laboratory tests to assure that they would be capable of adequately supporting the Porsche vehicle while allowing it to reach its top speed on the German Autobahn. Additional laboratory, test track and race track tests are conducted to confirm that the prototype tyres meet Porsche's noise, hydroplaning and handling requirements.
Prototype tyres will also be evaluated to assess their high-speed durability, uniformity and serviceability. Upon test completion, the tyres will be released for production.
Production tyres that have passed all of the tests and received the engineering department's release can be branded with an N-specification.
The N-specification brandings include: N-0 (N-zero), N-1, N-2, N-3 or N-4. These markings on a tyre's sidewall clearly identify them as approved by Porsche for their vehicles. The N-0 marking is assigned to the first approved version of a tyre design. As that design is refined externally or internally, the later significant evolutions will result in a new generation of the tyre to be branded with N-1, N-2, N-3, etc., in succession. When a completely new tyre design is approved, it receives the N-0 branding and the succession begins again.
It is recommended that only matching tyres be used on Porsche vehicles. Since many Porsche vehicles are fitted with differently sized tyres on their front and rear axles, this means matching the tyre make, tyre type and N-specification. If a vehicle was originally delivered with N-specification tyres that have been discontinued and are no longer available, it is recommended to change all four tyres to a higher numeric N-specification design appropriate for that vehicle. Mixed tyre types are not permissible.
It is also important to know that while Porsche N-specification tyres have been fine tuned to meet the specific performance needs of Porsche vehicles, the tyre manufacturers may also build other tyres featuring the same name, size and speed rating as the N-specification tyres for non-Porsche applications.
These tyres may not be branded with the Porsche N-specification because they do not share the same internal construction and/or tread compound ingredients as the N-specification tyres.
Using tyres that are not N-specific is not recommended and mixing them with other N-specification tyres is not permisable.
Tyres should be replaced no less than in pairs on one axle at a time. Only tyres of the same tyre make and type must be used. However, in case of tyre damage such as cuts, punctures, cracks or sidewall bulges that cause a single tyre to be replaced for safety reasons, the remaining matching tyre on that axle must not exceed 30 percent wear. If the remaining tyre has more than 30 percent wear from new, it should also be replaced. Handling inconsistencies may result if this is not done.
Initially, new tyres do not offer their full traction. Drivers should therefore drive at moderate speeds during the first 60-100 miles (100-200 km).
If new tyres are installed on only one axle, a noticeable change in handling occurs due to the different tread depth of the other tyres. This happens especially if only rear tyres are replaced. However, this condition disappears as new tyres are broken in.
Drivers should adjust their driving style accordingly.
Migration info. Legacy thread was 89736
yup - its cool. :D
My 911 has just been refitted with new 265/35/18 N4 Pirelli P-zero Rosso rears....
Matching the N4 front tyres.
Migration info. Legacy thread was 89845
Any of these guages will accurately measure your pressures .. prices range from 5 to 25 pounds ... Tyres must be cold (before driving more than 2 miles) and set to the manufacturers recommended pressures.. which are in your drivers manual :D :D
/images/migration/UploadedForumImages/guagescfsss.jpg :D :D
Migration info. Legacy thread was 97847
Good read that...
Well done stevo
Migration info. Legacy thread was 98015
It's nice to know that Porsche put such demands on the tyre manufacturers.
Cheers Stevo.
Migration info. Legacy thread was 98029
So what Pressures would you say I should run on Fridays Track day ? :wink:
Migration info. Legacy thread was 98044
Doesnt matter - your car is too loud!
:D
Unfortunately - so is mine.
Migration info. Legacy thread was 98054
Nah... I will be fine..
I have the same RSR's as Mick..
Migration info. Legacy thread was 98063
I have Gert RSR's
No undertray
an airbox like Swiss cheese
Migration info. Legacy thread was 98068
I have Gert's RSR's, A few holes in my air box, but an under tray !!
Migration info. Legacy thread was 98079
I have RSR, under tray, and a few bits of plastic remaining on the airbox. You'll be fine, otherwise we'll just go and have breakfast while the others go play spinning round and round!
Migration info. Legacy thread was 98082
Cheers Mick...
:wink:
Migration info. Legacy thread was 98083
Dan you will be fine, keep it quiet on the drive past :wink:
Migration info. Legacy thread was 98085
124,043
1,436,640
48,433
benny-g
