Porsche Health Check
monet100
18 May 2013
63
Took my car to the OPC today for a health check, to see if they would find anything that needs doing. Sat there for a couple of hours nervously.
They found all 6 downpipe bolts are corroding on the exhaust, they marked this as amber, and would charge £324
Both rear tyres Bridgestone Potenza's outer 4mm, middle 4mm, inner 3mm, they marked this as red, and would charge £301.24 each fitted.
That's all they found, I thought I got off lightley. They even gave the car a wash and a hoover and I din't have to get my wallet out.
You could probably get by with the bolts as they are for another 6 months before forking out, but I would change the tyres immediately. I had a similar result recently when I took mine for a health check (the vacuum and wash are part of the service).
Both my rear tyres required replacing. After obtaining various quotes I went with Black Circles and found a pair of Pirelli P Rosso N1 fitted for £567. It was very simple, and the cheapest price. You could ask OPC for a price match.
911_AS said:
You could probably get by with the bolts as they are for another 6 months before ***** out, but I would change the tyres immediately. I had a similar result recently when I took mine for a health check (the vacuum and wash are part of the service).
I was going to see if I can get away with the tyres for a bit longer, and look at replacing the 4. The fronts are 6mm outer, 6mm middle and 5mm inner. If I just replace the rears with the Bridgestones then I am stuck with Bridgestone tyres. I would have liked to look into which tyres would be the best for the money.
Are the Bridgestones about as good as you can get,? The michelin Pilot sports get a better rating for noise etc. The other thing that concerns me is getting the correct N rating tyre, I do not know where to look to ensure they are N rated.
Most of the sites that sell them will specify N somewhere in the spec if they are N-rated; blackcircles, mytyres, kwikfit all do.
Most sites will allow a reg number search too which should bring up your n-rated options.
124,285
1,443,761
49,397
246dbo
