Dammit: - It makes cira 285 ft/lbs at 4600, its at 250ft/lbs by 2500, and doesn't drop below this until 6750.
Demon: - Going by your signature we are indeed treading similar pathes. – When I actually think about the resonator, it makes sense, removing it does not increase airflow to the engine, but it does increase the noise, how does it do this, by upsetting the airflow. – You could also question why Porsche would add the resonator if it doesn't contribute anything.
Jcharalambides: - What is the spec on your engine build? 3.9?
Infra : - The 3.6 comes with less problematic heads out of the boxes and is probably a better place to start than the 3.4, however, and this is personal, I prefer the look of the 996.1 aero which I was set on when I started, being honest I didn't initially plan on the engine work!
Y2K : – Cheers for the dyno link, this further confirms to me that 275ish, are where the 3.4's are, interestingly the torque seems low, circa 225 ft/lb - Would be interesting to see what the 3.6 M96 is making.
I was surprised at the weight on mine, and was hoping to be closer to 1250kgs particularly based on the numbers that are banded around the internet, unfortunately not.
I know I can lose more, the standard wheels are heavy, I could save 20kg's there as an easy win, I have previously had a set of Oz alleggerita, actually had two, but I wanted to stick with the standard look so moved them both on.
I do however have a set of 996 Cup Magnesium E88's that I will eventually get around to fitting, the saving will be less than the Oz's, circa 15kg, but I can live with that as I think the wheels rock , out and out weight saving is not the ultimate goal.
Tyres are also a place to save that is often over looked, with most concentrating on the wheels. When the car was weighted it was running Yoko AD08R, which are a great tyre, but heavy, a 225 is heavier than a 245 Cup 2, the E88's will run with Cup2's, which are also a quicker tyre.
Lightweight battery, Odessey etc is an easy, cheap, big win on weight, however can be problematic if you dont keep it constantly on a ctech. - Li could be the perfect solution but I have no experience.
The JRZ's are superb, however, they are an out and out motorsport damper and as such are designed to run with high spring rates on race cars. - As the spring rates are high you also need to run lots of compression and rebound to ensure the damper is damping and your not just sat on the spring, I made this mistake at Thruxton when I had initially fitted them and it led to losing the rear coming out of Village!
All of this means a stiff ride, perfectly compliant on smooth surfaces, but rutted B roads, not so much!
Being transparent the whole suspension setup and geometry does not really lend itself particularly well to large swaths of British roads!
Spring rates for context.,
996 GT3 runs R: 370 F:200 - Revised on the 996.2 GT3 to R: 542lbs F:228
Cup Car: R:1484 F:1370
I run, R:950 F:800 (Main springs, both with 150 tenders)
My fronts are probably a little too stiff, noticeable on track when braking hard on bumpy surfaces, brings in the ABS when the tyres still have traction, most annoying, I can counter via the rebound damping, to an extent, however I think a little softer would dial out a little more understeer and help with the braking.
Your welcome to try it, do you track your car? trackday meet?
