So I bought a Blaupunkt 420BT thinking it was a plug and play replacement for the CDR23 I have (non MOST). When I install with the existing loom I get the word 'telephone' flashing and no functionality on the 420BT. Blaupunkt say that pin A2 has to be connected but the OEM ISO has 'reverse' in this position (blue/grey wire).
Is this standard for all aftermarket units, what have others done?
Thanks.
If not connected it is likely to ground, the wire is disconnected when permanent "phone" appears in the display.
Thanks.
