jerzybondov
- Joined
- 27 Apr 2015
- Messages
- 591
Thanks for all the updates - as drmark says keep us posted on the conclusions of CG’s subframe inspection.
My recently sold 2005 Carrera S did not need a single suspension component replaced in the 10 years I owned it and believe me, I drove it hard. I used the same Indy during this time and they were astounded that nothing perished. The suspension remained tight throughout my time with the old gal. I think my bushings were made of kryptonite!I did the full refresh at CG, including shocks. But don't expect it to last 10-15 years. In the 5 years - and 20k miles - since mine was done I have had to have 2 further coffin arms and toe links all round (also done by CG). These cars are very hard on bushes and toe links. At least they are on the roads around me...
Like everyone else on this thread, and many others, I've only ever experienced and heard good things about CG. I've taken my two 997s there and on both occasions they've gone above and beyond.Hopefully I’ll get to collect my car from CG later this week. I’ll get the full story then…
Chassis Heights | Front | Rear |
Porsche OE specification | 133mm | 153mm |
My car on its stock springs (before) | 124mm (-9mm from OE spec) | 145mm (-8mm from OE spec) |
My car on Eibach Pro springs and modified rear stocks (after) | 106mm (-18mm from stock springs) | 128mm (-17mm from stock springs) |
Amen to thatI think letting your wallet chill abit is the best option right now
Amen to that
Thanks Neven, that is a very timely update. I have just tracked down the creaking on my front suspension and it is the bush in coffin arm that connects to the sub-frame. I was just about to push the button on Meyle parts when I read this. I have now ordered the OE Match parts kit with bolts from Design911 instead now.Further to the above, I did promise to share the outcome of the 'complication' associated with the suspension refresh.
I sought permission from Pete to do this write up, and he was more than happy for me to do so.
The crack in the front aluminium subframe was actually caused when Pete attempted to torque up the bolt that holds the front drivers side coffin arm. There was nothing untoward, but nonetheless, this is what happened. Initially, Pete sought advice from CG's engineering partner who sent over a welder to assess whether the subframe could be repaired. The chap was confident he could repair it with a TIG weld; however, it turned out his portable welding equipment couldn't work off of AC power, and CG didn't have a DC power supply in their workshop. This being Friday afternoon at this point, it was therefore arranged for the welder to come back on the Monday morning with AC compatible equipment. As it was clear I wasn't going to be driving my car home, I caught a train home instead.
After dropping me to Atherstone station, Pete returned to the workshop and discussed the situation with Chris. They decided to whip the subframe off of the car so that the welder could do his work on Monday morning without having to work in the confines of the wheel arch. They also decided to order a subframe replacement as a fall back.
On the following Monday, the subframe was repaired as per the photo below. I've drawn a red line to show where the crack was before the welding repair:
Whilst all this was going on, Pete turned his attention to why this would've occured in the first place. Straight way he suspected the Meyle coffin arm way have been undersized. Essentially, when he started to torque up the bolt, with there not being much resistence coming from the arm on the other side of the casting, this may have cracked it.
It was important to Pete that he found out exactly the root cause because he didn't want to risk further damaging my car on the passenger side, or indeed the repaired side. However, this is bread and butter work for CG and he didn't want this to happen to any other customers' cars. So with that in mind, CG actually took a selection of front coffin arms out of their stock (inc. Meyle and Porsche OEM), and they additionally bought a series of equivalent parts from multiple suppliers, including more Meyle, Porsche, CTE, Optimal, and OE Match from Design 911. Pete has since accurately measured around 20 arms both as they come straight out of the packaging, and also when they are compressed in a vice. He has photos of detailed caliper readings for each arm, and has logged all the readings in a spreadsheet. There have been some interesting findings...
Firstly, the bushings in all the arms manufactured in 2024, other than those from Porsche or Design 911 OE Match were undersized by around a millimeter. Some in their compressed state or a few in their uncompressed state. Arms from Meyle, etc. that were manufactered in 2023 were fine. So the initial findings indicate that there may have been a change in the specs for the bushings, or a bad batch. CG have escalated and are in dialog with Meyle - this is onging so I can't really comment much more this for now.
Given the above, CG feel they have to now measure the dimensions of any arm they fit. For my car, they have replaced the Meyle arms in question and have sent them back to Meyle via Design 911 who are also actively helping with this matter. They have used the Design 911 arms as the replacement. Until there is a satisfactory conclusion, Pete said they will only fit either Porsche OE or Design 911 OE Match components to a 997, and even then they will measure each components as part of their installation process.
Regarding the subframe, CG decided to replace the subframe on my car with the unit they bought in as a fallback. Pete said he has inspected my repaired subframe and it looks like a good strong weld; however, he said using it introduces a further unknown factor and he doesn't want to take that risk.
All in all, a somewhat dramatic turn of events that I thought would be valuable to share with this community. Especially if you are considering refreshing your own suspension as there are some important additional things to check.
I should also point out that CG checked the rear coffins arms too and have concluded the problem only affects the front arms.
