Porsche 911UK Forum
Oil leaks part 1 and 2 now finished ! April update
clinchy993
Well-known member
1 Jan 2007
6,761
I have been collecting bits over the winter and with Spa on the horizon I thought I better get a move on fitting this stuff
So off with the bumper and exhausts and all the heat exchanger ducting to do the timing chain cover cover oil seals and gasket fit the new cam covers also repaint some of the tinwear and change the plugs
You can see the gasket is falling apart and the oil around those cover nuts is due to the rubber olives under those cup washers having perished
Round 2 on Thursday :grin:
Nice work :thumb: they all need doing at some stage. Where did you acquire the new covers?
immensely satisfying when doing it all yourself isn't it, well done that man.
Glad you're not feeling left out, with us all taking our back ends to bits.
Do we get to see it clean, too?
I presume your just doing the lower cam covers?
Been there done that Pete when I got the car 18 months ago
also did the lower cam covers before but n/s is warped and going to target that rusty tinwear when its off
Whoa those KWs look nice :worship: Looks like the engine tray tinware gets quite a bit of corrosion :pc:
:popcorn: Great stuff :thumb:
Can't wait to get our cars out together come the spring mate, they are certainly getting a good pampering at the moment!
It only surface rust :eek:
Thought you might like this pic they are the Dogs bxllox
Well I started with good intentions this morning @ 9.30 but very quickly ground to a hault becuase I did not have a long enough 18mm socket to remove engine mounts which is funny because I have changed the mounts before
So I whipped out the plugs and started cleaning up the tin-wear also I could not resist putting one of the new wheels on just to see :?: :floor:
123,996
1,436,172
48,366
Arv13
