New IMS Fix Kit for Boxster 986/ 996 & 997
Design911
16 Sep 2009
101
MS Eternal Fix retro fit kit installs in-car without removal or disassembly of the engine required. The Cylindrical Bearing with Thrust Control design has a load capacity 5 times greater than the inferior, failure prone, Ball Bearing solutions on the market!
Why Cylindrical is Best?
Cylindrical Bearings have very high load bearing capacity, 5 times more than Ball Bearing. Cylindrical Bearings are used in, High Temp & Low Viscosity Lubrication such as Automatic Transmissions. They can carry extreme lateral pressure without wear to the friction surfaces. This is because the bearing friction surface is flat not concave.
http://www.design911.co.uk/fu/prod1...rade-Eternal-Fix-IMS-Boxster-986---996---997/
Interesting........would appreciate some techy comments GT4 et al ??
Add a (filter tap) DOF and it would be perfect!*
As it is it scores 9/10
To put that into perspective, I would score the competitors:
LN Engineering/Hartech new IMSB, stripped of seals and with DOF: 9/10
Nice new IMSB, stripped of seals and with DOF: 8/10
LN Engineeing/Hartech IMSB (no seals): 8/10
Nice new IMSB, stripped of seals: 7/10
Plain bearing and DOF: 7/10
Factory IMSB (dual row) with seals in place: 6/10
Factory IMSB (single row) with seals in place: 5/10
For completeness:
9x7.2/991 MA1: 10/10 (no IMSB)
All Mezgers: 9/10
Some others threads for ref:
http://www.911uk.com/viewtopic.php?t=88364
http://www.911uk.com/viewtopic.php?t=87672
*in concept, no idea on quality of materials or construction.
Trending content
126,794
1,473,629
52,374
Flat6ixDevelopment
