Major problems following lay-up
jeffd
8 Apr 2007
2
Just come to start car - 84 Carrera - following a 6 month lay-up. Car would not turn over. Battery ok - but engine will not turn over. Tried towing vehicle to bump start but as soon as clutch was dumped the wheels locked. I think engine is seized. Does anyone have any ideas of what I can do other than an engine out rebuild?
Migration info. Legacy thread was 131055
re-mortgage the house or sell a kidney would probably be a good start ! Sorry to hear you have some trouble, I',m sure you'll get good advice here.
Migration info. Legacy thread was 131060
very likely the oil has settled down to the bottom of the engine, causing the engine to seize, if that has happened then it's not good news, as there is a certain method to start a car that has been idle for a long time
won't mean a rebuild, although only a garage can confirm this, but if it has seized it could mean opening up to get lubricated and in an able state
but it needs to get to a garage
Migration info. Legacy thread was 131095
Bad news, needs garage attention I believe. As you know now these cars need to be used.
Good luck, I think it should be ok but do get a Porsche specialist to do the work.
Migration info. Legacy thread was 131112
After a sleepless night thinking the worst! £££££££ the issue has been resolved, but I still dont know the cause. Charged battery overnight just in case it was a bit low. Tried it again but still no joy. Set up to remove starter, then plugs but prior to begining thought what would happen if I tried to turn the engine using the pulley wheel below the fan. Used 19mm spanner on center nut (would not turn in clockwise direction) turned back approx 1 turn relatively easily. Had my son turn ignition key and hey presto it fired first time. Exhaust very smoky initially but calmed down after 5 mins. Lesson - try starting / using car more frequently to prevent a reoccurance. Any ideas on what it could have been?
Migration info. Legacy thread was 131272
Rust maybe?
Glad its ok
Migration info. Legacy thread was 131294
124,582
1,446,529
49,733
dlb81
