Headlight washer tube not connecting
skwerl
7 Jul 2020
14
I had to remove the drive side headlight form my 996TT. It went back in without any issues but now the washer jet doesn't work. when i remove the headlight again there's fluid everywhere so it looks like the "quick release" connection between the supply tube and nozzle assembly isn't mating correctly when the light locks in place. Lights work fine so the electrical multiplug must be ok. Light unit sits in place correctly, so not misaligned.
Is there a trick for getting them lined up?
infrasilver said:
It should all just line back up the same as the power plug did so check to see if the rubber tube has moved or dislodged?
yeah. it looks ok. Nothing is mis-shaoen or squashed in any way. All looks as I'd expect. I'm reluctant to remove the other light to compare, in case it does the same.
I might be able to get a scope in through the locking tool access hole, to see what's going on. It's impossible to see anything form the front
124,584
1,446,539
49,734
11erCharlie
