front coolant pipes - when they arent leaking
I had one leaky lower hose which I asked to be changed. The Indy found the other lower one was starting to weep so it made sense to do it while it was apart.
It all depends on the condition of the crossover pipes the rubber pipes fit into..
The rubber pipes that go into the plastic pipes and they can be changed .. ie gently levered out when corroded ..
The ones into the ally pipe however are a bit more difficult .. you can't lever these at all , the ally pipe will just distort and you are left with replacing it regardless ..
If the rubber pipes wiggle and pull out then ok .. in my experience , to be fair they are leaking when i get them .. plastic pipes and there's a good chance with the ally ones and no .
124,584
1,446,539
49,734
11erCharlie
