Porsche 911UK Forum
Fixable Under Warranty or Not
Jam911
Well-known member
31 Oct 2010
1,720
I have 3 problems I would like fixing and I would like to know if they are fixable under my Warranty or not:
1 Noisy A/C Fan - like sticking a stick into it
2 Side repeater is loose - the other side is not
3 Window seals smear windows when opened/closed.
4 The rear lights suffer from condensation
What is the general consensus.
FYI - The car is off to Byfleet OPC very soon for a service.
Without going through the warranty itself for specifics why not mention these things when it's in for a service and see if they'll have a look/fix for free as part of the service?
The aircon is covered (but not the desiccator).
My side repeater (by the wheelarch) came loose/was pulled loose. Hard to prove how it happened.
The LED was fine so it was just a broken clip on the housing.
Part was £15 (even OPC were surprised how cheap, cheaper than anywhere else I looked too), fitting free as was in the garage anyway.
It's actually super easy to fit yourself.
Below's a list of what's not covered
Non-exclusive list of parts can be affected by wear and tear:
exhaust system including catalytic converter
spark plugs
drive belt
drive shaft bellows
synchroniser rings
differential lock
clutch incl. release bearing
steering-joint bellows
shock absorbers
tyres
tyre sealing system
wheel bearings
PDCC reservoir
brake pads
brake discs
air conditioning desiccator
refrigerant
all bulbs (excluding Xenon and LED bulbs)
fuses
batteries
wiper blades
floor mats
fire extinguisher
door seals
all filters, hoses, fluids, oils and greases
I'd imagine anything which is just labour intensive to fix would be done as goodwill especially if you're putting a service their way.
I raised the condensation with my front lights and they said this wasn't covered under warranty and probably caused by the very cold weather period we suffered. Since the weathers improved it's been fine.
Hi Jam,
I had my front lights replaced under warranty at West London No Less.
I noticed it after a torrential shower a few months after purchasing the car.
Good luck
:thumbs:
Here is an update.
Fixed itself...weird
Fixed under warranty
Only happened once so put down to a wet Summer
All work done at OPC Byfleet, thanks for their help with the Warranty bits I think they tried hard, which is good.
Post service the car now feels very smooth.
All good
I get this sometimes;
What did they do to fix it?
Replaced the seals in the doors
Interested to hear of the fix too. This has happened on every 911 I have owned!
That alone will not necessarily be a permanent fix as the seals are not the original source of the problem, IIRC. The smearing is caused by grease which somehow" migrates" from the window regulator onto the glass when the windows are dropped. Let's hope they thoroughly cleaned any surplus grease off the regulator mechanism when the door card was off.
So, it's grease transfer from mechanism onto window, onto seal and back onto windows again?
Would cleaning the seals reduce the problem? Might need to be done regularly but would it eventually eradicate the problem?
I have seen mechanics spray nylon lubricant down the gaps before on other cars I have owned for 'squeaky' window problems. Is this a simliar issue - i.e. caused by wondering lubricant?
123,985
1,435,983
48,357
dirtyrdier00
