Exhaust rattle - valve?
jwb1380
18 Oct 2017
99
Folks,
Valve has sheered off, why does this happen? Help appreciated...
JB
I fixed this exact problem yesterday! The fixing nuts rust and completely disintegrate and then if the ball joint seizes (very common) the force sheers them off.
You can buy a replacement valve but mine was still functional so decided to fix it by grinding the remaining fixings flat, carefully drill 3 new holes into the valve and then pot rivet the surround to the valve with 3 flat head 5mm stainless steel bolts sandwiched between. I wish I took a photo as it's a lot easier than trying to describe that!
Even though I fixed mine I still left the actuator unplugged in the engine bay as I prefer the exhaust loud all the time
Forgot to add...
To remove the ball joint there is a small pin with clip around the shaft. Using a small screwdriver lever the round clip off the shaft and then the pin slides out
badbadtz said:
Forgot to add...
BBTZ,
Cheers for the feedback. Just ordered a new one today, good effort fixing yours. I have my valves open pretty much all the time also.
Thx,
JB
The pipe is attached using using an oetiker style ring clip so it's handy to have the pliers to crimp it again once you take it off.
I would also recommend packing the ball joint on both sides with an anti-seize or high temp grease to stop it happening again.
124,578
1,446,490
49,726
Z102B
