Engine oil change and correct grade of oil??
my996
24 Dec 2012
61
Hi I am going to do an interim engine oil change for my newly acquired 996 3.4 tiptronic. I have bought Mobil 1, 0w 40 fully synthetic oil and a Man oil filter. Could you please advise me if this is the correct grade/ specification for my car? As I havent carried out an oil change on a 996, but have on many other vehicles, could some please send me a diagram of under the engine and also advise me where the oil filter is?
0w-40 is OEM factory.
Technically, the oil grade is dependent on the actual requirements of your specific engine.
More worn engines require a thicker oil grade.
As your's is a Tip there is a good chance the engine is younger than its miles suggest (vs manual)
It would be nice to know the car's current grade.
If after the oil change to 0w-40 the hot idle (op temp) pressure is much below 2 bar, use a thicker oil next time.
If it is below 1.5 bar, you may want to change it now.
Any way, here is all you need to know:
http://p-car.com/996/diy/oilchange/
I was trying to find Infrasilvers clip of when he ordered the wrong size magnetic sump plug.
Always good to remind him!
gixxeruk said:
Ray doesn't trust any OPC to service his car :thumb:
"And that will burn ya, and we don't wanna burn ya. Do we?"
I like the " dont gnaws them threads up cos i'll have ya "
doesn't sound like he's joking :eek:
engine oil
What grade of mobil 1 would you recomend Paul for a slighly worn ,higher milege 996 after using 0w-40 ?
PM me your your cold idle, hot idle and and hot 3.5k rpm pressures. (ie at full op temp - after 20-30 min normal run)
125,611
1,457,581
50,940
T_jorel
