Engine noise - 996 turbo
melodasi
27 Jul 2012
90
Hello all,
Today when I had the car in idle I just check it underneath and the noise from the engine was like there was something loose.
Is this noise normal? I have no warning lights or oil pressure gauge is normal, etc....
Check the noise here.
http://www.youtube.com/watch?v=vteQ6X6LNVI
THanks
IMS gear rattle, all 996T's do it but some to different varying degrees of loudness. Have a good search (especially on 6speedonline where an owner stripped his engine down to investigate), in short nothing to worry about
Check the exhaust heat shields, these can make a noise if they have chattered through on the mounting points.
Some of these engines seem noisier than others but essentially as stated above there does not seem to be too much to worry about.
Mine sounds like that so guessing normal
Thanks.
Yes I started to think it is normal when I saw one in YouTube with the same noise.
Thank you
Mine rattle too, they all do it even 997tt. I am using Fusch 5w40 easter pro race and it did reduce the rattle a little bit. Don't worry to much. Get a sport exhaust to covert the noise !! :lol:
Maybe I should do that ;-)
124,818
1,443,889
49,323
xx22
