mightymetro
- Joined
- 2 Apr 2012
- Messages
- 174
Wonder if anyone can help. I need to make a fuse in my girlfriends mini switch using a toggle switch on the dash (to act as a battery reset due to a wiring loom error that BMW want to put a new loom in for!!!!!)
Basically, if i pull the fuse out and then put it back in it resets the BCM1 module so we can lock the car as it has a deadlock problem so wont lock the car without resetting first. Ive tracked it down to this fused circuit and if i pull the fuse, and then put it back in everything is fine.
So, i need to get the power from the fuse, to the toggle switch and then back again. Would one of these work?
http://www.ebay.co.uk/itm/ADD-A-CIR...arts_Vehicles_CarParts_SM&hash=item4ac261fa82
or does this just tap the original fuse and not allow me to turn the circuit off?
Just thought i would ask to save tearing all the panels out to get to the wire from the back of the fusebox
thank you
thank you
