DIY Gundo thread 2004 997.1
Mac68
Nurburgring
11 Mar 2021
416
As per my intro thread here
http://911uk.com/viewtopic.php?t=144581
I've purchased a 2004 997.1 that needs a little bit fettling.
I have quite a list of items from the PPI and that's before a garage garage hasn't seen it!
I had bought some parts for jobs that I know need doing and things I can do, which are the mufflers and the rear discs at this stage.
First up is the mufflers on the car, they're rotten so I picked myself up some used also rotten ones! Why? I intend to use them to experiment with the Gundo hack and I think I can fix them up and get a few years out of them.
I'm calling it the Gundo, it could be Fister I'm not sure which but I'm attempting the version that joins the inlet/outlet with a short pipe.
The used mufflers I bought I knew had seam root, one worse than the other but I thought that should be easy to fix however upon cleaning the mufflers I found some rust holes, impact damage on the muffler and couple of cracked pipe/muffler joins.
Here is one showing the original seam, this is the worst seam!
997.1 by The Shipwright, on Flickr
Better or least worst seam!
Cracked pipe/muffler joint
Rusted through hole in the muffler
Hole caused by impact, I assume
I had assumed I would shape and craft the seam repair part on the work bench but on the day I thought I'd tack one side place and see how easy it would be to manipulate, i.e use a hammer, to shape the new plate. I've never worked with 1mm mild steel so wasn't sure what it would be like. It shaped easily with and retained a smooth non hammered appearance.
Pic of muffler with some paint applied and the seam plate tacked on
20210320_151801 by The Shipwright, on Flickr
Nearly hammered all the way
20210320_151853 by The Shipwright, on Flickr
Seam repair in place weld unpainted, with my weld on show in all it's glory :oops:
20210320_153156 by The Shipwright, on Flickr
Painted seam
Pipe/muffler joints repaired again not the best of welds but I've not welded for 30 years!
Impact damage repaired
Rusty hole in muffler repaired (again not my best welding!)
I may revisit this repair, by removing the support bracket, dressing the welds and fitting a plate over the hole and then re-weld the support bracket on top of the plate.
Next up is the Gundo/Fister when the 40mm tubing arrives and new rear discs and then some motoring fun!
124,552
1,446,262
49,684
V164
