So you saw a spark when you connected your van battery to the emergency connector in your Porsche.... No surprise there... You are connecting a higher voltage to a very low voltage (if any) from that point on your van battery is dropping voltage as it is now charging your Porsche battery....
if you imagine it as two water tanks of equal dimensions one full the other empty, connected together via a pipe and a valve, you open the valve between the tanks and in time you end up with two half full tanks..... If you need a full tank to do the job...half a tank just wont do it...?
Water tanks have a floating ball valve to top up the tank to ensure the water level does not drop below a pre-set level in the tank...
When you fired up the van, you took some degree of power out of the van battery to get the engine running, after which the alternator was trying it`s best to bring two batteries up to the required voltage, which will indeed take TIME, and dependant on the alternators output capabilities...
Simples...?
Of course if I have got any of that wrong, I am more than happy to be corrected...
Simples...?
