shantybeater
- Joined
- 5 Sep 2012
- Messages
- 729
Hi All,
You may have seen my thread recently on the SAI error code. Bit of background - since buying the car (4 months or so) cold start has always seemed a bit erratic/lumpy. As the weather got colder the symptoms got worse. After fixing the SAI the problem has increased or is at at least prolonged
On start-up the car idles high, sounding a bit lumpy. Then when it tries to settle the car rocks and struggles to hold smooth, it sounds like its missing, infact it sounds like it will stall out (but never does). This continues for a good few minutes. If I drive the car it dips in revs and bucks on occasion, acceleration remains unsmooth for a minute or so of driving but as the coolant temp starts to rise the car settles and drives fine, smooth idle etc...
Once warm all symptoms dissipate and the car runs fine.
I have no CEL, no error codes logged. Does anyone have any suggestions on what could be causing this? MAF? coil packs? I have a Durametric, any ideas on what values I should try logging?
Thanks for any help
James
Thanks for any help
James
