Hi all, the gearbox on my 993 is always stiff when starting from cold, but is fine once everything is warmed up.
This morning (after a very cold night) when I started her up, the gearbox refused to engage in any gear with the engine running. If I tried to select a gear, the car creeped forward slightly (even though the clutch was in). In the end I switched the engine off and then I could select first and start the engine with the clutch in. Again, once warmed up everything was fine.
Any idea what causes this and what might fix it? I really hope it's not a new clutch or gearbox
Cheers.
Migration info. Legacy thread was 11644
Cheers.
