Porsche 911UK Forum
Changed the Car Stereo in the 996 GT3 to an Alpine! Wow!
Jibberingloon
Well-known member
10 Mar 2008
114
Well I've had the car 5 years and never bothered changing the stereo, but over the years I have driven a lot of new pork and the stereos were sooo much better.
Admittedly I normally listen to the flat 6 sound track, but its always nice to have some music every now and again :)
Anyway got bored on the weekend so bought an Alpine CDE 178BT so I could hook my iPhone up to.
My GOD
Just changing the Head Unit has transformed the sound quality in my car it's a 1000000 times better, I have no distortion and the bass is a lot clearer and I only have to use 60% of Volume rather than 95%....
The old Porsche Becker system was pooooooo, should have done this 5 years ago!
Anyway.....
Happy Man :thumb:
Hi
was it an easy install? Did it connect straight into the loom connector?
Sounds like a nice way to have music on the move from iPhone/iPod and blue tooth iPhone connection.
Thanks in advance
Simon
very very simple :)
Just spent £200 on the stereo
The Car Audio shop gave me a set of keys to take the becker one out.
I then had to buy an aerial adapter for £5
Wipped it all out
Put the cage in for the new stereo
The Porsche stereo plugs for Power and Speakers are all ISO so its just plug and play to the Alpine harness supplied.
Job done in less than 30 mins ;)
SIMPLE and have to say the sound quality is great :thumb:
:useless:
Hi, I thought these cars had a BMW-like system where the new stereo needs to be 'coded' to the car with appropriate hardware (e.g. at OPC).
I assume then this is not the case?
I will get some pictures on the Weekend :)
A how to.....
Will take it all out and then put it back in with some camera shots ;)
if replacing with a factory stereo you are right I believe
By any chance is this a Gen 1 996 GT3?
The 996.2 MOST bus head unit is supposedly not so straightforward to upgrade...
OP has an '03 MK2.
I think you're confusing the intricacies of interfacing the CD changer & the Bose system, which do use the MOST bus, with a simple replacement of the plain old CDR-23 head unit used in the GT3, which is pretty old-school.
Just to clarify.
Its a basic CDR 23 so No Bose and No Changer
If this is the radio you have its a simple swap over.
The standard Porsche Wiring loom is a ISO
and it has a different aerial that you need to get an apater for (Can differ between models (So remove radio to look first before buying!
This was mine
Can be
or
Other than that you have to wire a permeanent live from either the fuse box, or heater or cig light, and then connect this to the New Radio head unit.
Other than that its SIMPLE :)
Oh and you need a set of Becker Radio removal keys.
Here are some images from Pelican Parts
Thanks.
All looked simple until you mentioned the part about wiring a live connection?!
I can do simple DIY/electrics...is this simple DIY/electrics?
Its simple ;)
Find live feed from either Fuse Box drivers foot well, or behind the dash, lighter / ignition.
Put a wire in and feed it to the back of the radio with a nice connector.
The problem is the porsche ISO only has a switch live.
All new radio's need a switch and a perm live. (Yellow & Red) on the wiring harness.
I will take a picture on weekend
Did exactly the same on my 996 GT3, and it definately makes a huge difference. However, then removing my silencers made the whole stereo exercise, a little pointless, as I can't hear a thing when driving..... :dont know:
124,008
1,436,291
48,385
DocGastro
