Battery Issue or Component Drain Issue?
SpennyUK71
29 Jan 2018
28
Hi all
I have an issue with my battery draining within a few days and I am not sure if this is an issue with the battery or something draining the battery?
The reason I ask if this is a battery issue, is that I accidentally let the battery drain completely flat over a few months and I wonder if this has damaged the battery which is 3 years old? The battery has since drained completely flat on a couple more occasions.
At the same time, I had an issue with the door lock actuator being faulty and not dropping the drivers window, so I wondered if this faulty part was also draining the battery. I have since changed it (with at excellent eBay purchase at £27 compared to the £200 OEM part) and the battery is still draining.
Before I look at replacing the battery, I thought I would seek some wisdom on here, so any advice would be greatly appreciated!
For those interested, this is the door lock actuator I bought:
https://www.ebay.co.uk/itm/PORSCHE-...2349624.m46890.l49286&mkrid=710-127635-2958-0
Cheers,
Spenny
Best way I've found to try and pinpoint a battery drain is put a multimeter temporarily on dc amps between the battery positive and the disconnected main battery cable (you need radio code etc) with the ignition switch off. You will get a mA reading of the drain. Now systematically remove fuses and note any significant drop in the current reading on the meter to pinpoint the circuit the drain is on.
Many thanks 👍
If you let the battery run completely flat, it's probably shafted now.
With a 3 year old battery which has been key run totally flat, i'd Replace it anyway.
124,471
1,445,535
49,611
JCGMS
