Alignment
Dunc
26 Jan 2003
1,259
What's the general opinion on alignment check/adjustment - have it done at the OPC for accurate settings or use the audi dealership 'cos its closer (and considerably cheaper) for the same work?
OPC have quoted 3hrs labour (usually about £65 an hour)
Dunc
Migration info. Legacy thread was 22389
If it's a 993 then make sure you go to someone who knows what they're doing, as the car's quite sensitive to alignment changes. Ask if they can check the kinematic toe in, and if they say "you what?" then walk away as fast as you can. Even some well known independents send the car out to dealers for the alignment. I do know JZ is ne of the few who can do it properly, with computer print out before and after adjustments.
Migration info. Legacy thread was 22391
Cheers Mick, it is a 993 and a C4 at that so probably just stick it into the OPC just to make sure.
Car has been tramlining and bump steering since it was last in there for engine out oil leak repairs but they assured me that they hadn't touched the suspension etc settings.
Migration info. Legacy thread was 22392
i got a quote today from OPC East london
Yes sir we can do that - its3 hours labour - so that will be £387.75 then
Hmmm - i'll pass then!
Migration info. Legacy thread was 22471
Tognola down by Heathrow charged me £140 back in the summer...
Migration info. Legacy thread was 22477
Got mine done when having new tyres fitted on the C2S. Can't remember exactly what it cost as I have passed all the paperwork on with the car, but I think it was less than £100 - which part of the UK are you in Dunc?
Migration info. Legacy thread was 22488
I'm in Central Scotland so i'd have to travel a long way to get to a specialist, hence why I end up at the OPC to be relieved of cash.
Booked it into the Glasgow dealer tomorrow, got fed up with the car feeling so edgy.
Dunc
Migration info. Legacy thread was 22501
Toby, just re-read your post realised that your quote is about £130 an hour?!!!!
I get labour at the OPC for £60 - £75 (depending on work and haggling). Think that all OPCs should be offering cheaper rates for more elderly vehicles
Migration info. Legacy thread was 22512
OPC East London did mine twice under warranty - still felt wrong so took it to Autofarm who found it way out of spec but they took a long time to correct it and hence a big, big bill - fortunately settled direct by OPC East London.
Besides having the right equipment, it's also down to how good the person is doing the actual adjustment I'm afraid.
Jo
Migration info. Legacy thread was 22543
Dunc
Your problem is that you are in Scotland. You should seriously consider moving down south where you will have a good choice of specialists who can do this work far better than the OPC's. I wouldn't ask my OPC do mine as it is a major factor in the way the car handles.
I've used Camtune and Parr previously at a cost of around £140-£160
Migration info. Legacy thread was 22549
the labour works out at £110 per hour plus vat - i think i will contact camtue or jzm
Migration info. Legacy thread was 22557
I had mine done in an OPC in Northampton a while ago, car still felt "wrong", eventually went to JZ, they found the alignment way out, toe OUT instead of toeing in!!! Just to show how some OPC have no idea about "older" Porsches. Never went there again and never will.
Migration info. Legacy thread was 22563
Previous poster said:
Quote: Originally posted by jonathan cosh on 12 January 2005
DuncYour problem is that you are in Scotland. You should seriously consider moving down south where you will have a good choice of specialists who can do this work far better than the OPC's. I wouldn't ask my OPC do mine as it is a major factor in the way the car handles. I've used Camtune and Parr previously at a cost of around £140-£160
Dunc , sod the OPC's, how are you fairing with this weather?
Migration info. Legacy thread was 22567
phoned around today prices were (all ex VAT)
JZ Machtech - £220
Parr - £177
Paragon - £204
Tognola - £140
so compared to the OPC at £330 plus vat they all seem cheaper - henry seems to rate tognola for alignment - any others been used here?
Migration info. Legacy thread was 22679
Well, took the car for a good run yesterday (Hendo - weather was great for a change), it felt at least as good as it did before the OPC messed it up the last time.
OPC charged £200 which I think is ok considering my location - it would've cost me a lot more to travel to a specialist.
Can now fling the car about in an amateur fashion without the fear of death I had until recently! Got a full print out of the alignment results and targets also.
Dunc
Migration info. Legacy thread was 22710
124,598
1,441,975
49,034
briant1000
