Local OPC no use on the sport button upgrade… but have sent them the part number off the Porsche website
HAve you gone ahead with the Sport/Sport+ upgrade? If yes, did you buy the dasboard Module (99704490302) from Porsche or elswhere?
Its immediataly before this one
When I picked up my 997.2 in August I felt my PDK was clunky especially immediately post thrashing.
When my mechanic did the work he emphasised that the PDK was very unlike my previous Tiptronic gearbox and that the PDK just isn't 100% smooth (unlike the Tip) as it's an automated dual clutch manual gearbox not an automatic gearbox. If I'm being honest that's all a bit lost on meOnly ast week i spoke to my Independant about my occasioanlly clunky PDK, but to be honest I haven't yet thrashed mine. That might change once I have Sport/Sport Plus fitted.
My clunkiness is most notable when the car is cold. My Independant said it's normal to be clunky when cold. Mine is MY2009 with 55,000 miles. When it next goes in for a service I might ask for the oil to be changed. Also I'll do some resarch about the PIWIS, and ask my Independant about it too.
Driving again today, seems adaptions have taken place. Car is a rocketship through gear changes. It almost feels like it has now enhanced the ECU Custom Map done by GAD Tuning, feels like its pulling harder from lower down. Although, I think this is probably some placebo effect
Ninemeister suggested the increased torque capacity and clutch line pressure speeds up the shift and keeps everything smooth. There is noticeably less clutch-slip during the shift and they are noticeably smoother
Time to do another 100-200kph run to check any overall performance increase.
Last attempts after the ECU Map were
Run 1 - 10.22
Run 2 - 9.53
Run 3 - 9.73
Hi Veetwin thanks for the review got mine booked in for wc25th so will be able to compare notes!TCU is now back in the car. Took it out for a test drive yesterday to adapt clutch/shifts.
Initial observations -
Auto mode very similar to before but the clutch operates more smoothly at slow maneuver speeds (reversing, parking)
Manual Mode in Sport Plus the gearbox feels a lot faster to shift at lower revs. There is more of a snap to the shift at lower revs, whereas before it felt the clutch slipped when changing gear to make it smoother. Full throttle shifting at redline is very quick and seems that the 'thud' is now gone
Sadly, they couldn't find a way to change the code to reverse the +/- shift pattern on the manual shifter. It would take hours of code to do.
