997.1 Drivers window wont go all the way down
Luckstar997
7 Aug 2021
9
Hi all.
The window goes up and down fine but it won't go all the way down. It leaves about 3cm of the window exposed. It's level, not sticking and works well apart from this. The passenger side is working perfectly.
I tried a reset by holding the switches up and down for 3 seconds and that didn't work.
Does anyone have any ideas on how to sort this please?
Thank you
If it was a 996 I would say it had had the regulator changed for a Boxster one and the stop hadn't been adjusted. Not sure if that is the same on the 997.
yes, i can vouch for inadvertantly leaving the stop for the boxster when fitting the 997 regulator! :?:
OP; if its always done this; this is your answer
Ah that makes sense. I bought the car last month and noticed one of the most recent repairs was a new window motor, as you say, maybe the stop wasn't removed. I will try and work out how to get the door card off and try and remove it.
Thank you
As above. The small bolt that acts as a stop at the bottom of the regulator track needs removing (put there for Boxsters).
Recently replaced the regulator on passenger window with new OEM item.
Any job worth doing is worth doing twice...
when you can't figure out why the window doesn't drop enough and you should have watched the YouTube video till the end...
Remove the stopper on the front side of the slider!
Luckstar997 said:
Is this a whole door card off job or is there a shortcut?
By no means an authority on the topic, but I don't see how it can be done without removing the door card.
Not too bad a job. Be gentle on the plastic clips... especially the small triangle piece covering the wing mirror part...
124,808
1,448,757
49,998
manx100red
