996 Turbo X50 Geo settings
P911X50
Nurburgring
3 Jan 2017
430
Hi
I've just bought a set of new tyres for my 996tt and want to ensure the geo is set up right. We're in lockdown and I am shielding. My only option is my local no porsche specialist as I can't get to CoG
Would anyone here have any recommendations on setting they have used. I'm looking at normal driving and a bit of fast road. I have 5mm spacers on too.
I'd take the spacers off, standard Porsche settings then put the spacers back on.
P911X50 said:
Hi
I experimented a lot with stock suspension before making the transition to Ohlins.
As a starting point, try these. Assuming road only performance.
Front. 50 mins camber
Front 2 mins toe or zero, whichever feels best
Rear. 1 degree 35 mins camber
Rear. 10 mins toe PER SIDE, 20 in total.
This should feel quite nice on the road, but getting 50 mins of camber on the front is about the limit.
Give that a try and adjust from there. Make sure they achieve even numbers from side to side, this is pretty imperative, even if you pay them extra for the time taken.
Hope that helps.
Mike.
Hopefully, the file attachment works. These are the settings CoG used for my car with Ohlins R&T, no spacers.
  • suspension_set_up_graphic_143.pdf
Perfect for the road. Comfy and super stable.
Must feel nice to drive, with good turn in and stability over bumpy roads. 👍
Are these settings with load in the car?
Fuel tank empty, half or full?
At CG they insist on a full tank of fuel. My particular car has been set up with the drivers weight in the seat, just not at CG.
124,535
1,446,073
49,663
NBavers
