Porsche 911UK Forum
996 paint - do they have masking lines???
my996
Well-known member
24 Dec 2012
61
Been looking at a very clean 996 1998 3.4 in metallic blue and I noticed that there were what appeared to be masking lines on the inside if the front wings, arround the bottom of the door shuts near the kick panel and areas in the engine bay. There was no evidence of over spray at all. There was what appeared to be the undercoat paint visible, the same colour but not metallic or laqured. Is this correct?I was advised that this was from factory and how Porsche are finished! I would appriciate your help and advise please
It sounds as if you are describing the sealant used to protect the underbody against damage by gravel, etc.. This is oversprayed with the final body colour. Sometimes it will show through where the paint has been chipped off.
Thanks for your reply. It didnt appear to be a sealant. As I said it is around the the inner front wings where they bolt on in side the front boot area. Also when the door is opened it can be seen on the sill/ door kick panel and going up the B pillar to approx the latch.
That isn't the sealant I was referring to. Sounds as if some repainting was called for at some stage of the car's 14 year life.
Hi there
I have this too - inside the door frames
will confirm or take photo next time i open the car
digby
+1 but a good shop should have buffed this out..?
Maybe but i believe mine is original Porsche..............
124,090
1,437,024
48,483
7CUU
