996 mk1 gt3 front discs
Ps as someone above said are the 350mm discs from the mk2 GT3 available aftermarket? If so getting those and some 10mm caliper spacers may be an alternate way forward. Changing the 330mm discs on the 996t to the 350mm from the 997t with 10mm spacers is a popular conversion so 10mm caliper spacers should be readily available!
Mac
Thanks so much for the advice. I'm getting why it's important now. Just checked and the total depth is around 69.5mm and the contact face thickness is 6.a bit. So all within 0.1 or 0.2mm of the Brembo spec. Only the weight seems significantly different. Think I'll take the plunge if i can get a sale or return on a pair from someone. Will report back as it's about a £650-700 saving on Porsche. I can make up the 2kg weight gain by losing some fat.
Hello again. Just trying to get it all back together now. Can anyone recommend a scan tool so I can cycle the abs while I'm bleeding the brakes? Even better, borrow one. Or have you just bled the brakes, gone for a drive and then bled again?
As long as you haven't let the brake fluid reservoir run dry, there is no need to cycle the ABS when you are bleeding the brakes. As you say, bleed them, go for a proper drive to get the calipers and discs hot, come back, bleed them again and enjoy the next two years until it needs to be done again.
126,832
1,474,179
52,422
Mab901
