Here you go ...
Maintenance every 20,000 km/12,000 miles
Diagnostic system: Read out fault memoryChange engine oilV-belt or Polyrib belt: Check condition and tensionChange spark plugs (only on vehicles without catalytic converter)Visual inspection for leaks: Oils and fluidsAir filter: Replace filter elementAnti-pollen filter: replace filter insertCrankcase ventilation: Check tightness of hose connectionsFuel system: Visual inspection for damage, correct position and tightness of connectionsIntake air system: Check hoses, lines and connections for tightnessHandbrake: Check free travel of handbrake leverBrake system: Visual inspection of brake pads and disks for wearBrake hoses and lines: Visual inspection for damage, correct position and corrosion, check brake fluid levelClutch: Check play or final position of clutch pedalThrottle valve actuation: Check for ease of movement and full throttle positionResonance flap and Varioram: Check operation (Carrera only)Steering gear: Visual check of bellows for damageTrack rod links: Check play and dust capsPower steering/clutch: Check fluid levelsAxle joints: Visual inspection of dust caps for damageScrew connections of suspension adjustment system: Check for tightness front and rearManual transmission/axle drives: Check oil levelAutomatic transmission : Check fluid levelDrive shafts: Visual inspection of sleeves for leaks and damageExhaust system: Visual inspection for leaks and damage, check attachmentTyres: Check condition and pressureDoor hinges: LubricateCheck door, lid locks and safety hooks on front lid for tightness and operationSafety belts: Check operation and conditionSeals for doors, compartment lids and roof: Remove abraded rubber, apply suitable lubricantVehicle lighting: Check operationAll headlights: Check settingHorn: Check operationWindscreen washer, headlight washer: Check fluid levels and nozzle settings; in winter months top up with anti-freeze as necessaryAll other electrical equipment as well as indicator and warning lights: Check operationIgnition circuit 1 and 2: Check operation (Carrera only)
Maintenance every 40,000 km/24,000 miles
Automatic transmission: Change fluid and ATF filterToothed belt for power steering: Check conditionReplace spark plugs (only in vehicle with catalytic converter)Replace both engine oil filters
Maintenance every 80,000 km/48,000 miles
Replace fuel filterManual transmission/axle drives: Change oilAutomatic transmission: Change oil in axle drive
Maintenance yearly - after the first 2 years
File Status Report for Long-life guarantee
Maintenance every 3 years
Change brake fluid (Only use Original Porsche Brake Fuild)
Maintenance after 4, 8, and 10 years, thereafter every 2 years
Check airbag system
Recommended Yearly Maintenance
Change engine oilVisual inspection for leaks: Oils and fluidsDiagnostic system: Read out fault memoryHandbrake: Check free travel of handbrake levelBrake system: Visual inspection of brake pads and disks for wearCheck brake fluid levelSteering gear: Visual inspection of bellows for damageTrack rod joints: Check play and dust capsAxle joints: Visual inspection of dust caps for damageDrive shafts: Visual inspection of cup seals for leaks and damageExhaust system: Visual inspection for leaks and damage, check attachmentTires: Check condition and pressureSeals for doors, compartment lids and roof: remove abraded rubber, apply suitable lubricantCheck operation of lighting systemWindshield washer, headlight washer: Check fluid level and nozzle settings; in the winter months top up with anti-freeze as necessaryBattery: Check electrolyte level and densityAll other electrical equipment as well as indicator and warning lights: Check operationFile Status Report for Long-life guarantee (after the first 2 years)Test drive: Foot brake and handbrake, clutch, automatic speed control, steering, heating, air conditioning and instruments: Check operation
Ian.
Migration info. Legacy thread was 31634
