991 High Lvl Brake light inop
Monaco
21 Mar 2015
11,242
The spoiler brake light inop ..
The broken wire issue is pretty well known and you will get a dash warning message if this happens .
Car i've just had in had no dash warnings and was merely found to be not working on a service ..
Spoiler removed and a wiring check .. all ok .. ohms reading for the light unit being an led system was 10 K ohms which is actually correct but i powered it up out of the car and indeed it worked .
Spoiler back in the car and on a tester the car could see that the spoiler was extended but it didn't switch the center brakes lights .
No feed was found to be coming from the rear end control unit to turn on the lights when it should .. control unit issue obviously .
A little bit of thinking and i considered a coding issue perhaps , there is an option for a fixed wing on these so perhaps its coded to that ..
On these cars you cant see individual coding in each control unit but only in a master list and of course yup it was listed as a retractable spoiler ..
On a hunch i hit auto coding of the rear end control unit ( BCM rear )
Brake lights now work correctly .. somehow the control unit had decided it had a fixed wing !
best guess would be from a flat battery at some point .
Not something i've ever seen before .
In short .. spoiler brake light inop with no dash warning and have the rear cu auto coded with a tester ..
It will save you the 1.5 hrs it took me to track this one down.
124,576
1,446,481
49,724
markevo6
