Hi Clive
Obviously there is quite a lot to look out for - in fact books have been written on the subject. Obviously books are no good to you at this late stage but for future reference you might find "Used 911 Story" by Peter Zimmerman to be helpful
I have attached a check list you can use when looking at a 911 (although it is not specifically aimed at the turbo). You can copy and paste it into Notepad and it should look fine.
What you should be looking for is the normal stuff e.g.
1) Exterior2) Interior3) Mechanicals
As a "layman" there is not a lot you can look for that you wouldn't look for on any cay e.g. panel gaps, rust, signs of accident damage under carpets etc. If it looks OK to you, and drives well (again the usual stuff of brakes not pulling, gearbox feels OK, turbo works!) then you need to take it to a garage for PPI including a leakdown test.
As for some specifics:
1) Panel gaps are quite wide on 911s but they should be even2) Check that a previous owner hasn't pushed down too hard when closing the bonnet or engine lid - either can dent the panel3) Check for rust around the bottom of the windscreen and rear screen (happens if glass is replaced poorly). Any visible rust is just the tip of the iceburg4) Check for rust on the tops of wheel arches, front & rear5) Lify carpets under bonnet to look for rippling or new paint - either is a sing of accident damage6) Lift carpets inside car for same7) Check carpets in front and rear foot wells are dry - if wet then leaking somewhere and bound to be rust8) Check condition of headliner. If saggy or water-stained the sunrook may be leaking9) Check condition of exhaust - expensive to replace10) Check for oil leaks - may be signs of oil but shouldn't be wet and certainly not visibly dripping. Have a look at where the car has been parked11) Check for rust around where suspension joins the car. Should be fine. If not will be expensive to fix12) Check each gear will engage OK. The gearbox will feel loose but you should be able to engage each gear without grinding.13) Engine will suffer from heavy lag (unless modified) but should pull like a train over 4000 rpm14) Oil pressure should read 1 one the scale for each 1000 rpm (approx)15) Engine should start easily and idle flat after a few seconds just under 1000 rpm16) Check there are the same brand/type of tyres all round - if not the owner has been cutting corners17) Ask the owner not to warm the engine up before you get there
I am sure I had missed loads but that is a start.
The list below should help you assess the car when you get home in the cold light of day.
Good luck and have fun
James
___________________________
Last-modified: Wed Jul 26 18:42:25 PDT 1995Version: 2.2
---------------------Copyright 1995, Wade Guthrie. Permission is granted to copyand redistribute this Document so long as it is unmodifiedand the copyright remains in-tact.---------------------
NAME/ADDRESS/PHONE . Car _________________________________ . . Price _______________________________ .
DATE:
== PHONE ===================================================================== VIN ____________________
Miles ___________________________ How Long Owned __________________ How Many Owners ____________________ Records _________________________ Where maintained ___________________ Color ___________________________ Last Paint Job _____________________ Interior Color___________________
Wheel sizes _________ Tire sizes _________ [ ] Original Color [ ] Original Engine [ ] 5 speed manual Induction ____________ [ ] Air Conditioning [ ] Alarm Radio ________________ [ ] Large Fuel Tank [ ] Gasoline Heater [ ] Electric Windows [ ] Electric Antenna Why Selling, Notes:
== RECEIPTS ================================================================== [ ] Carrera Tens'ners Last Overhaul ____________ [ ] Rebuilt Inj'n pump (mfi) [ ] Shuffle Pin (f) [ ] Dilivar Studs (f) [ ] Timeserts (f)
Compression 1:____ 2:____ 3:____ 4:____ 5:____ 6:____
== LONG DISTANCE ============================================================= Have the owner send receipts and pictures. If you can, have the owner send a videotape. The tape should cover the following: - Walk around the car, SLOWLY - Get closes-up (check for rust & mating) of: headlights, door seams (door closed), hood, trunk, fuel filler, - Get under-car shots including: suspension pickups (front and rear), jack receiver area, and tortion bar tubes (under car). - Interior shots (take-off targa top, if applicable). Get: front seat, rear seat, dash, instruments, console (if applicable) carpeting - Engine compartment - Trunk area (lift carpet around batteries). Have owner take the car to a mechanic. Maybe have owner take the car to a body shop (check for rust).
Check seams for evenness and for rust (portal closed) [ ] left door [ ] right door [ ] fuel filler flap [ ] hood (mating) [ ] trunk
Check for rust (under car): [ ] left jack receiver [ ] right jack receiver [ ] front suspension [ ] rear suspension [ ] headlights [ ] tail lights [ ] under windshield [ ] trunk area (lift carpet around batteries)
Interior (take-off targa top, if applicable) [ ] front seats [ ] rear seats [ ] dash [ ] carpeting
(RECEIPTS, MECHANIC)
== INSPECTION (bring magnet, ice pick, flashlight) ===========================Name ____________________ Phone ____________________ Car ___________________
GENERAL A B C D F Paint, chrome, trim A B C D F Rubber A B C D F Dents/Dings A B C D F Undercoat all around (e)
LEFT SIDE DOOR: VIN Drivers door jamb (post '69) ____________________ A B C D F Mating A B C D F Edge, bottom (r) A B C D F Hinge A B C D F Strike Plate (r) A B C D F Jack receiver (r) A B C D F Underside rocker panel (r) A B C D F Side windows & seals A B C D F Body under windshield (r)
TOP A B C D F Targa top seal A B C D F Targa top condition
LEFT FRONT FENDER: VIN Windshield post (post '69) ____________________ A B C D F Tire condition A B C D F Fender Lip Texture (a) A B C D F Fuel filler (r)
TRUNK: VIN (post '73) ____________________ A B C D F Headlights (pull out, rust & bracket squareness) A B C D F Cross-member in front of gas tank (been beaten flat?) A B C D F Suspension pickups under car L&R (r) A B C D F trunk lid: fit (r) A B C D F trunk lid stop (r) A B C D F Battery Box (r) A B C D F Front bumper - fit A B C D F Spare tire A B C D F Jack and toolkit
RIGHT FRONT FENDER A B C D F Tire condition A B C D F Fender Lip Texture (a)
RIGHT SIDE DOOR A B C D F Mating A B C D F Edge, bottom (r) A B C D F Hinge A B C D F Strike Plate (r) A B C D F Jack receiver (r) A B C D F Underside rocker panel (r) A B C D F Side windows & seals A B C D F Body under windshield (r)
RIGHT REAR FENDER A B C D F Tire condition A B C D F Sight along body (accident) A B C D F Suspension Pickups (d) A B C D F Texture on fender lip (a) A B C D F Pinch Welds (g)
ENGINE LID / COMPARTMENT: VIN Under hood (pre '74) ____________________ Engine number (vertical fan housing) ____________________
A B C D F General condition A B C D F Belts A B C D F Oil leaks A B C D F Transmission fluid leaks A B C D F Exhaust system A B C D F Rear Valence (accident)
A B C D F Tail & parking lights A B C D F Brake lights, signals A B C D F Backup lights A B C D F Seams/Fit (accident)
LEFT REAR FENDER A B C D F Tire condition A B C D F Sight along body (c) A B C D F Suspension Pickup (d) A B C D F Texture on fender lip (a) A B C D F Pinch Welds (g)
INTERIOR: [ ] Leather [ ] Sport seats [ ] Head Rests A B C D F Front Seats A B C D F Rear Seats A B C D F Carpeting A B C D F Floor pan/pedals (r) A B C D F Air Condonditioner A B C D F headliner A B C D F Dashboard A B C D F Seat adjustment (L&R)
== TEST DRIVE ================================================================ A B C D F Starting A B C D F Acceleration A B C D F Braking A B C D F Alignment A B C D F Steering 2 3 4 5 Synchros
A B C D F Clutch pedal free play A B C D F Brake Pedal Firmness A B C D F Clutch slippage A B C D F Idle (fluctuations) A B C D F Valve sounds A B C D F Clutch chatter A B C D F Other strange sounds A B C D F Blip throttle (miss=inj'n, _________ Oil pressure (warm) smoke=valve guides)
== MECHANIC ==================================================================Name ____________________ Phone ____________________ Car ________________Mechanic ________________ Phone ____________________
Everything required to bring the car to street-concours, itemized and costed
1:____ 2:____ 3:____ 4:____ 5:____ 6:____ compression (130-170 +- 15%) 1:____ 2:____ 3:____ 4:____ 5:____ 6:____ leakdown (< 3-5%, 10% max)
[ ] Numbers Match [ ] Engine number match [ ] Worn Valve Guides
[ ] Carrera Chain Tensioners [ ] Spring Centered Clutch (b) A B C D F Tie rod ends A B C D F CV joints A B C D F Ball Joints A B C D F Bushings A B C D F Shock absorbers/struts A B C D F Brake lines
A B C D F Structural Rust A B C D F Cosmetic Rust A B C D F Front susp. attachment A B C D F Rear susp. attachment A B C D F Torsion bar tubes (F&R) A B C D F Lower control arms (F&R) A B C D F Floor pan-(F&R) A B C D F Floor pan-battery area
--------------------------------------------------------------------------Resolution: VINs / Engine No. Match Rust Accidents Mechanical Condition
(a) since 1969 (b) 911SC only (c) check for accident damage (d) The rear suspention pickups are bolted to the pan under the car roughly aligned with the torsion bar tubes -- check for rust. (e) Fresh undercoat is bad. If you see it, check to see what mischief it covers. (f) These are not required if the car isn't a 2.7 liter or heavily built-up car. (g) Make sure the pinch welds aren't bulging or separating. (r) check for rust
Migration info. Legacy thread was 387
