991 : 2011- 19
997 : 2004- 80
996 : 1997-2005 33
Boxster : 1997- 25
imp75
PostPosted: Wed Feb 04, 2015 11:14 pm    Post subject: Reply with quote
I'd like to see what the paddled wheel looks like in situ. Distinct but subtle difference I expect.
AndrewM
PostPosted: Thu Feb 05, 2015 12:39 am    Post subject: Reply with quote
I was considering what these would be like today but it seems to me that the indicator stalks are very close to the wheel. do they interfere with the use of them?
beebman
PostPosted: Thu Feb 05, 2015 10:03 am    Post subject: Reply with quote
Hi All,
As requested, some pics of the wheel in situ. ignore the colour mismatch as its a test wheel not some sort of fashion statement Very Happy
shaun
beebman
PostPosted: Thu Feb 05, 2015 10:18 am    Post subject: Reply with quote
I'll try that again. PC
nicholas lawrence
PostPosted: Thu Feb 05, 2015 10:50 am    Post subject: Reply with quote
Paddles work lovely - I've not complained about my 'tip box since having em!
https://www.facebook.com/media/set/?set=a.10152267763086875.1073741841.669721874&type=1&l=f3cff38d0d
beebman
PostPosted: Fri Feb 06, 2015 12:00 pm    Post subject: Reply with quote
 Filesize:  225.12 KB
 Viewed:  6304 Time(s)
 Filesize:  96.59 KB
 Filesize:  206.66 KB
nicholas lawrence
PostPosted: Fri Feb 06, 2015 12:05 pm    Post subject: Reply with quote
You're heavy!
Looks mint man! x
nicholas lawrence
Why is the airbag thing a different colour?
beebman
PostPosted: Fri Feb 06, 2015 1:20 pm    Post subject: Reply with quote
Hi Nicholas,
I purchased a cheapest wheel I could find on eBay to test the paddles and work out how best to fit them. Didn't fancy hacking up my wheel until I was sure that the paddles worked and the spacing of the paddles was correct.
shaun Very Happy
AndrewM
PostPosted: Fri Feb 06, 2015 1:47 pm    Post subject: Reply with quote
Looks like a top job. You posted previously that you would do a full guide. Is that still on the cards?
beebman
PostPosted: Sat Feb 07, 2015 10:43 am    Post subject: Reply with quote
I'll probably put something together when I convert my actual wheel. At the moment I'm testing the grey wheel to make sure everything works correctly.
shaun Thumb
RichS1963
PostPosted: Sat Feb 07, 2015 1:10 pm    Post subject: Reply with quote
And if someone could insert the relevant tech bits for multi func wheels re resistors etc, that would be really helpful...
AndrewM
PostPosted: Sat Feb 07, 2015 2:28 pm    Post subject: Reply with quote
Cheers Shaun, your work is appreciated.
beebman
PostPosted: Tue Feb 10, 2015 9:09 am    Post subject: Reply with quote
Hi All,
While nosing on the net last night for Porsche bits, I came across the company that make the paddles for the Porsche Design Steering Wheels.
http://hdo-gmbh.com/cms/en/content/steering-wheel-switch-paddle#
It turns out that they make the paddles for K & L / TRW who provide Porsche parts. I wondered if you could source them directly for the manufacturer or the reseller and save some money as well as having the correct paddles on the car. Anyone got any idea of how you would go about sourcing item directly from suppliers?
shaun Question
mkoenigsheim
PostPosted: Thu Feb 12, 2015 3:34 pm    Post subject: Reply with quote
Damn Beebman - respect. you must have balls of steel to try this 1st!!
well that and a spare wheel Wink
my paddles arrived yesterday and i spent the best part of 4 hours today making them work.
scary moments drilling a hole into the wheel and then cutting squares out...
couple of photos on the next post.
Apologies I didn't get the chance to make a how to - I did this from my office..
anybody has questions feel free to PM me.
I can confirm that for the sport wheel with no multifunction, no resistors are required - very simple to connect 4 cables.
upshift - yellow cable to the white (more dark cream) colour, black to black
down shift, red to the yellow cable on the paddle, black to black.
if you look carefully you will notice i got the down shifter wrong- it is a little higher than the up shifter - i placed it in the right place but when i drills the hole for the securing bolt i drilled at the wrong angle.
the paddles don't fit 100% at the rear - clearly that would be a miracle if the wheels had 100% the same shape and form but they feel rock solid
however I am a happy bunny - paddles and buttons all work perfectly.
thanks also to Klaus for the schematics
mkoenigsheim
PostPosted: Thu Feb 12, 2015 3:38 pm    Post subject: Reply with quote
pictures....
[img][/img]
[img][/img]
medicus
PostPosted: Thu Feb 12, 2015 4:15 pm    Post subject: Reply with quote
looking at your photos here, I see you did not opt for recessing the shift paddle's completely, as you can see the small brass pin etc., I made mine completely flush, by cutting more of the old steering wheel away, as the paddle's were flat, and the wheel convex, it was awkward, but with a bit of black mastic, it looks factory fresh.
I have done 5 of these now, and its true what they say about getting better each time (lol) I have the first prototype on my car, done about a year ago, and the latest ones are away with jack at royal steering wheels, being re trimmed this week.
great job anyway sir, well done.
medicus
PostPosted: Thu Feb 12, 2015 4:19 pm    Post subject: Reply with quote
on a separate note, I ran the original wires from my tip buttons down through the clock spring, and left them unconnected by my centre console, im in two minds as to what to use the redundant buttons for? im thinking perhaps radio volume, or possible passenger seat backrest, for the young ladies?????
obviously you can have them as tip control, but why have both button and paddle? better use them for some other electrical function, like rear spoiler up?
what do you lot think?
mkoenigsheim
PostPosted: Thu Feb 12, 2015 4:21 pm    Post subject: Reply with quote
Andrew - no more than on any other car - I have an Audi with paddles and they are a similar gap.
you just need to be careful with the placement - any further out to the side and they would get in the way i think.
But if you look at other cars - these are in pretty much the same position close enough to be easy to get to but not be in the way of your thumb
Actually you need to be very careful with the placement to make sure that the screw connecting them isn't in the way of the original switch - it is apparent when you have the airbag off and look where you would need to drill a hole for a screw..
carruthers
PostPosted: Thu Feb 12, 2015 5:39 pm    Post subject: Reply with quote
Anyone done this sort of thing with a PDK wheel ?
Goto page Previous  1, 2, 3, 4, 5  Next
Page 2 of 5
