964 : 1989-1993 6
Boxster : 1997- 17
Cayman : 2005- 12
Cayenne : 2003- 3
Macan : 2014- 1
beebman
PostPosted: Tue Jan 27, 2015 2:03 pm    Post subject: 997.1 Tiptronic Paddle Shift Conversion Reply with quote
Hi All,
It seems that for a long time 997 owners with Tiptronic have wanted to convert their steering wheels to paddle shift. I too am one of those owners, so I decided to have a look to see if it was possible. There are a multitude of threads on different forums, but no one seems to have a proper answer to the is it possible question.
I have some experience with electronics and know one end of a soldering iron from the other so I thought how hard can it be. I managed to get a cheap wheel off eBay (didn't fancy hacking mine up to find out that its no possible) and a set of AMG paddles too. well, I've had a go and the good news is that it is possible, not expensive and wont require any reprogramming.
So far I've only tested the paddles with a Tiptronic wiring loom, but will be testing a multifunction wiring loom in the next few day. All you need to do is solder the two wires on the paddles onto the wiring loom, its as easy as that - well apart from cutting a hole in the back of your steering wheel. If you use the AMG paddles, you'll need to cut a rectangular hole in the back of the wheel down to the alloy frame. Once this is done you'll need to drill two holes in the alloy frame. One for the cable and another for the retaining bolt.
you have a connector on each Tiptronic switch, this is where you need to connect the wires from the paddle too.
Tiptronic Wiring
For the UP paddle (Right hand side)
A8 - White (tip control)
A7 - Black (Earth)
For the Down paddle (Left hand side)
A8 - Red (Tip Control)
A7 - Black (Earth)
http://www.ebay.co.uk/itm/Original-AMG-aluminium-performance-paddle-shift-NEW-left-right-/251789381152?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item3a9fd10e20
I'm happy to answer any questions on the mod. I'll post more pictures once I've wired things up and got the wheel on the car. I may even post a vid on youtube to prove it works.
happy tinkering
shaun Very Happy
RichS1963
PostPosted: Wed Jan 28, 2015 6:40 pm    Post subject: Reply with quote
This is on my 'must do' list. But chickened out without a comprehensive how to explanation, preferably with pics.
If you can post a pictorial or video link, that'd be great. 😁
beebman
PostPosted: Wed Jan 28, 2015 8:54 pm    Post subject: Reply with quote
Hi RichS1963,
I have taken some pictures, but need to do a few more. Will post a vid showing the wheel working on the car. I'll try to put a tutorial together at some point. Here's some pics of the wheel with the paddles fitted so you can see some progress. I haven't done the wiring yet, but will do this on the weekend.
regards
shaun
 Filesize:  55.15 KB
 Viewed:  18922 Time(s)
 Filesize:  44.87 KB
RichS1963
PostPosted: Wed Jan 28, 2015 8:56 pm    Post subject: Reply with quote
Great start. Looking forward to the next instalment.
Jacko9370
PostPosted: Wed Jan 28, 2015 9:28 pm    Post subject: Reply with quote
Do you fancy making one to sell?
beebman
PostPosted: Wed Jan 28, 2015 9:35 pm    Post subject: Reply with quote
Hi Jacko9370,
The wheel I'm working on is a spare that I'm using as a test bed. If everything works I'll being doing the mod on the wheel on my car. I will probably sell the test wheel if all goes well. I'll put a post up If I do decide to sell.
regards
shaun
Jacko9370
PostPosted: Wed Jan 28, 2015 9:39 pm    Post subject: Reply with quote
beebman wrote:
Hi Jacko9370,
regards
shaun
I shall look out for your post.
Many thanks
moritz
PostPosted: Wed Jan 28, 2015 11:17 pm    Post subject: Reply with quote
Attach paddles parallel to std Switches, add Resistors (- 150, + 300 +/- 10%) into the wiring as per attached dwg. The std switches remain still active.
Works here flawlessly since 12 Month. It's a new car ;-))
The mechanical attachment is a little carving work – drill the hole for the fixing screw from the inside (remove PU layer) close to the hole for the remote housing. The hole for the cable about 10 mm below. I will try to find my olde pics…
The switches have a connector – remove the housing, fiddle wires through the hole (5.5 dia) and attach housing again. Solder a solid wire which fits (.75 ?) the connectors to the loom Extension, so it can be removed w/o butchering.
Have fun!
sorry - the attachment of a .pdf seems not to work (I may be stupid) - I am happy to send per PN
declandio
PostPosted: Thu Jan 29, 2015 7:07 am    Post subject: Reply with quote
There is a very good detailed DIY how-to on this (using AMG paddles) on renntech.org where the author installs the paddles on the back side of the steering wheel and retains the original tip buttons. They're wired in parallel so not only are the original buttons retained, they still work.
Edit- sorry I don't think its renntech after all. I bookmarked it on my home laptop so will dig out a link and post it later this eve after work.
beebman
PostPosted: Thu Jan 29, 2015 2:57 pm    Post subject: Reply with quote
thanks for the extra info guys. Especially the resistor values. Smile This has saved me working them out.
shaun
medicus
PostPosted: Thu Jan 29, 2015 3:10 pm    Post subject: Reply with quote
could you please tell me the reason for the resistors? is it not just a case of swapping the paddles for the switches?
moritz
PostPosted: Thu Jan 29, 2015 3:18 pm    Post subject: Reply with quote
Sorry, I have to confess that I forgot to limit the instructions to the MF wheel (shematics 4A). David showed me that on a std wheel they seem to be designed it w/o resistors. The anti collision logic there is in the wiring.
The shematics (4B) are not absolutely clear on this, I suggest one checks the wiring/switch in the loom direct. I had never looked at one, but I wonder why they should come up with two different looms. In any case, one can hook the paddle Switches then in parallel to the std Switches.
The idea with the resistors is obviously to slim down the fat looom in the MF wheel. The switches are both connected to ground and the up/down signal is generated by coding the ground via the hi/low resistors through one wire (high/low voltage) to a small electronic box doing the anti collision logics and generate the "switch gear" signal to the gearbox.
Is there a way to attach a .pdf file here?
beebman
PostPosted: Thu Jan 29, 2015 3:33 pm    Post subject: Reply with quote
Hi Moritz,
think you need to add the attachment via the add an attachment option below the window you type the post. With regards to the resistors, are they connected to the ground or the tip single wire. Also, I assume the values are 150k & 300K.
cheers
shaun
moritz
PostPosted: Thu Jan 29, 2015 3:49 pm    Post subject: Reply with quote
I tried the attachment mechanism w/o success - my stupid?
The resistors (MF wheel only!) need to be in series with the paddle Switches. I am happy to mail you the schematics - just PM me.
The actual resistors in the wheel are 135 and 270 Ohms - I jaust had 150 and 300 sitting around...
mkoenigsheim
PostPosted: Thu Jan 29, 2015 4:38 pm    Post subject: Reply with quote
Wow - this has been on my todo since i got the car - if anybody can find the how to link or do a write up I would be the happiest guy in Germany....
I have a tip car with no multifunction.
beebman
PostPosted: Fri Jan 30, 2015 9:06 am    Post subject: Reply with quote
Hi mkoenigsheim
Just follow the instructions below for wiring paddles to a standard Tiptronic steering wheel. I'll hopefully do a write up or something when I've finished my wheel.
good luck
shaun
Tiptronic Wiring
A7 - Black (Earth)
A7 - Black (Earth)
mkoenigsheim
PostPosted: Fri Jan 30, 2015 12:32 pm    Post subject: Reply with quote
Thanks Craig - Moritz also sent me the schematic. I knew this must be possible but wasn't brave enough o do what you did worship
I am relatively good with electronics and soldering - rewired the 997.2 switch box last year into my car.
I have ordered the paddles so soon i will be giving it a go as well...
worst case I will be trawling eBay for a new wheel next month 'Very Happy'
Captain Lockheed
PostPosted: Sat Jan 31, 2015 11:05 am    Post subject: Reply with quote
I was looking into doing this on my Mrs' Tip with multi function wheel.
I had worked out a couple of things, then saw this.
Thanks so much for sharing.
I think there is a company called edition9 who have done this to 996 steering wheels, but not 997's.
medicus
PostPosted: Sun Feb 01, 2015 10:50 pm    Post subject: Reply with quote
apart from the cosmetics, the principal is exactly the same for 996/997, they use the same AMG style paddle shifter, and the wiring is the same, in fact you can swap wheels (from 996 to 997) with the air bags, and clock springs.etc.
i taped the AMG shifters in place (as a template) marked round them with a marker pen, then cut away a small section in the middle of the template, and marked where the drill hole needed to be to secure them in place, a further small hole was drilled for the wires, and job done, its that easy.
sharp craft knife or good stanley, and a 5 and 10mm drill bit.
beebman
PostPosted: Wed Feb 04, 2015 10:39 am    Post subject: Reply with quote
Hi All,
Finally fitted my test wheel to the car and everything works fine. In the end I purchased some resistors from Maplins. Managed to get 270ohm for the up shift and 150ohm for the down shift (the resistors only apply if you have a multifunction wheel). Got to say that it really does make a difference having the paddles on the car. Changes the driving experience for the better. I'll post some pics when I get a chance.
shaun Very Happy
Goto page 1, 2, 3, 4, 5  Next
Page 1 of 5
