997 : 2004- 65
996 : 1997-2005 33
Cayman : 2005- 22
Macan : 2014- 8
LMR
PostPosted: Mon Apr 27, 2015 7:07 pm    Post subject: Reply with quote
A google search last night showed that I had wasted my time fitting the bumper reinforcement.... frustrated
Anyway, I cracked on this morning. I should have remembered sooner, but one of the brackets on the bumper needed a repair.
So I trimmed a bit of plastic and shaped to suit
Some two pack glue and a clamp
And some further two pack gave me something I can fettle later
So, onto reassembly. New reinforcement piece to the bottom of the bumper riveted on
Reinforcement pieces (powder coated, obviously) fitted
Lots and lots of assembly later
And a little bit of wrestling, and lots of crawling around on the floor later (and half covered in waxoyl), I now have this
Still need to tighten the side pieces. I have fitted new rubbers, which have very little give. If anyone is thinking of doing this task themselves, the screws listed in the Porsche parts catalogue are only just long enough. after struggling for far two long, I used the longer bolts listed for the front bumpers - which made life far, far easier.
Right, must eat, absolutely shattered.
S A Watt
PostPosted: Mon Apr 27, 2015 7:24 pm    Post subject: Reply with quote
This is absolutely fantastic
I have been following the post for months now and can't wait to see the final results.
This car will be mega once you finish it and you should be really proud of it.
I'll keep watching and you enjoy once you finish it
Porsche Cayman 3.4 GTS
Volvo S60 RDesign
BMW 1200RT
Triumph Street Triple
Yamaha yzf600 Thundercat
Harley Davidson Vrod. (The Porsche engine one)
LMR
PostPosted: Mon Apr 27, 2015 8:22 pm    Post subject: Reply with quote
Thank you for your kind words. Today has been long - I am glad people enjoy my ramblings Smile !!
Gazc2
Watkins Glen
PostPosted: Mon Apr 27, 2015 8:48 pm    Post subject: Reply with quote
Its coming along nicely Thumb in regards the bumper reinforcement you could have left that on , where the cover slips under lip on the top of the bar if you put self tappers in there rather than rivets makes it easier if you ever have to take the bumper cover off in the future you unbolt from the rear quarters, the two support brackets on the underside of the middle section and take the self tappers out the top lip and slip the bumper cover off
2007 997 Turbo & 924s Restored
1990 964 C2
1989 3.2 targa
1987 3.2 Cab
1986 3.3 Turbo
LMR
PostPosted: Mon Apr 27, 2015 8:52 pm    Post subject: Reply with quote
Gaz
Now you tell me!!
Thanks for the tip - I am clearly a masochist, therefore I have done the rivets.
Gazc2
Watkins Glen
PostPosted: Mon Apr 27, 2015 9:02 pm    Post subject: Reply with quote
Sorry mate missed your post last night nooo no biggie just means you will need to drill the rivets out in the future, I have a twin exhaust on mine which makes it a nightmare to get to the brackets/bolts on the reinforcing bar
hope neither of us have to take them back off !
1990 964 C2
1989 3.2 targa
1987 3.2 Cab
1986 3.3 Turbo
PeterS
2003 Porsche 996 Carrera 2
PostPosted: Mon Apr 27, 2015 9:05 pm    Post subject: Reply with quote
The design and fitting of the rear bumper assembly has to be one of the daftest ever.
Cars looking great, though.
LMR
PostPosted: Tue Apr 28, 2015 6:57 pm    Post subject: Reply with quote
Just a quick update today. After finishing off fitting the rear bumper this morning, I have spent the rest of the day cleaning stuff ready to fit - wheel arch liners, front lights and indicators, replaced all of the bulbs and and a seemingly a thousand other things, none of which seemed worthy of photos.
What I did get done was fit the rear lights (after waxoyling the bowl and behind the centre section), together with a new seal on the top of the reflector. Very satisfying Very Happy
Chief
PostPosted: Tue Apr 28, 2015 8:15 pm    Post subject: Reply with quote
Looking good Phil,
With all that waxoil the car should last indefinitely Grin
LMR
PostPosted: Tue Apr 28, 2015 8:33 pm    Post subject: Reply with quote
I think it will float.......!!
Pressure is on, next project arrives in 9 days time (supposedly)....
Chief
PostPosted: Tue Apr 28, 2015 8:43 pm    Post subject: Reply with quote
Just ordered engine bits for mine. At least it's cheaper than 964 stuff Thumb
LMR
PostPosted: Wed Apr 29, 2015 9:49 pm    Post subject: Reply with quote
Late one in the workshop tonight, but some good progress made. First off I fitted the remainder of the lights. I was very pleased when they all worked!
I then went to work with more rust proofing. In the cavities I have used dinatrol and on the surface, clear waxoyl. This is a picture of the sill. The brown / black is the dinatrol coming out of the drain holes
I have also rust proofed the wheel arches. Again, you will see a mix of shiny brown and clear. I have used dinatrol on the surfaces that won't be seen (particularly behind the plastic liners) and clear waxoyl elsewhere.
This is a super messy job, but I think well worth it.
To compensate for the messy task, I wanted to do something which changed the visual appearance of the car. So I thought I would pop on the outer sill cover. New seal fitted pretty easily, and wasn't a massive hassle to get the seal to sit correctly.
Right, shower and bed - and back to it tomorrow.
Happy reading
Chief
PostPosted: Thu Apr 30, 2015 12:30 pm    Post subject: Reply with quote
Looking good Phil. I recon you could park it next to the sea for a decade and not see any rust Grin
LMR
PostPosted: Thu Apr 30, 2015 7:00 pm    Post subject: Reply with quote
Chief
I am not going to test that theory Hand
Lots done today, but little of worthiness to photo. Nearside sill cover fitted, number plate lights, collected what I thought was my last set of parts from OPC. Wheels were due back from powder coaters today, but won't be ready until tomorrow.
I did get distracted for part of the day. I am going to the Stanford Hall VW show at the weekend, and as the rust proofing stuff was lying around, I applied some underseal to my motorhome, and new disk brakes.
I also found that the fittings I have for the rear spoiler are knackered, so will be spending this evening trawling through the parts catalogue ordering a few more parts......... frustrated
LMR
PostPosted: Fri May 01, 2015 9:56 pm    Post subject: Reply with quote
Just back from the potting shed. I have been fiddling with other stuff for part of the day, but finally got around to the 964 mid afternoon. I have been refitting wheel arch liners, which I have to say is not the most pleasurable task I have ever done, but just one of those tasks that needs doing.
Whilst in the arch I also fitted the rear bumper support bars
And because it was messing with chief's OCD (and mine), I also removed the overspray off the radius arms
Before
After
I also completed the fitting of side sills and the sharks fins - no photos are people have covered this in other blogs.
Cant remember if I mentioned this before, but on Sunday I looked at my tyres and realised they were not going to pass an MOT. I had decided that I was going to defer wheel refurbishment until a later date, but As I needed tyres fitting, it made sense to get them done now. I picked them up today.
After lots of time sorting through bags of fittings to get the arches fitted, and with the wheels having arrived, I pressed on, fitted them, and took the car off the axle stands.
Still lots to do, but having a car back on 4 wheels feels really good thumbsup
LMR
PostPosted: Fri May 01, 2015 10:38 pm    Post subject: Reply with quote
Why is it, the closer the car gets to completion, the more messy my workbench gets Dont know
PostPosted: Sat May 02, 2015 2:05 am    Post subject: Reply with quote
Great work Thumb
The game's afoot. It's time to put a bit of (Colini) stick about......Why RUF when you can WUF
PeterS
PostPosted: Sat May 02, 2015 5:49 am    Post subject: Reply with quote
Looking good, I'll have to find time to pop round with Chief and see it in the flesh again.
You can see light at the end of the tunnel now.
paul284pt
PostPosted: Sat May 02, 2015 12:32 pm    Post subject: Reply with quote
Hi Phil,
I'm really looking forward to seeing it out from under the covers, it's going to look mint!
Great work Thumb
Paul
1980 - 84 924 Turbo with mods. (ex Tony Dron - 12th at Le Mans 1980 with works 924 Carrera Turbo).
1984 - 89 911 SC (1982)
1989 - 93 911 Carrera Sport (1989)
2010 - 964 Carrera 2 (1990) Redtek 3.8RSR
2012 - 14 Porsche Cayenne (2012)
2015 - 17 Porsche Cayenne Diesel S (2015)
2017 - 18 Macan Turbo Performance Package (2017)
2018 - 991.2 Carrera 4 GTS (2018)
LMR
PostPosted: Sat May 02, 2015 3:41 pm    Post subject: Reply with quote
Chaps
Thank you for all of the kind words Thumb
Goto page Previous  1, 2, 3, 4, 5, 6, 7, 8, 9, 10  Next
Page 8 of 10
